WD 4TB My Passport for Mac 2.5" USB 3.0 Portable Hard Drive
Key features
  • Secure and reliable
  • Compatible with Apple Time Machine
  • Sleek design with high capacity
  • Ultra-fast transfer rates
  • You're in control
Product codes
chevron icon
chevron icon
My Passport for Mac
My Passport for Mac is the sleek, portable hard drive designed for photographers, graphics professionals and road-warriors who want to take their digital life with them. It's compatible with Apple Time Machine and is an ideal companion for your MacBook or MacBook Air. Password protection and hardware encryption let you secure your files from unauthorized access.
Built for Mac, Time Machine-Ready
Ready to go with your Mac straight out of the box, the My Passport for Mac drive helps protect your files with Apple Time Machine backup software. And you can quickly drag and drop files to and from the drive with Finder.
Password Protection with Hardware Encryption
Built-in 256-bit AES hardware encryption with WD Security software helps keep your content private and safe. Add a 'return-if-found' message as the password prompt in case your My Passport for Mac drive ever gets lost.
Easy to Use
Ready to use out of the box with your Mac, you can start transferring files, saving memories and backing up. The My Passport for Mac drive works with Apple Time Machine, and included WD Security software helps protect your data.
Reimagined Design
Designed to complement your Mac, the rich, black shine and artful composition makes the My Passport for Mac drive fashionably fun.
Massive Capacity
With up to 4TB, you can take the massive amounts of photos, music and videos you love wherever you go, and have plenty of room for other important documents, too.
WD Quality Inside and Out
WD builds drives to demanding requirements for durability, shock tolerance and long-term reliability. And we stand behind the trusted My Passport for Mac drive with a 2-year limited warranty.
chevron icon
Product Description WD My Passport for Mac WDBP6A0040BBK - hard drive - 4 TB - USB 3.0
Type Hard drive - external (portable)
Capacity 4 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Password authentication, hardware encryption, automatic backup, Apple Time Machine compatible, HFS+ formatted
Power Source USB bus
Enclosure Colour Black
Dimensions (WxDxH) 110 mm x 81.5 mm x 21.5 mm
Weight 250 g
Localisation Worldwide (excluding China)
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
