ITEM | QTY | PRICE |
Asus ExpertBook B1 Intel Core i3-N305...
4 | £1,585.00 |
Logitech K750 Wireless Solar Powered...
4 | £308.08 |
Poly Plantronics CS540/A with APS10 E...
1 | £162.22 |
WD Elements USB 3.0 external hard drive is an easy-to-use, reliable way to add more storage to your PC or Macintosh. Simply plug it in to a USB port and start saving or backing up your photos, music, video, and files. It's preformatted for immediate use so there's no software or CD to load. The compact, durable metal case provides extra data protection helping keep data safe from loss.
Product Description | WD Elements Desktop WDBWLG0040HBK - hard drive - 4 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 4 TB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Features | NTFS formatted | Power Source | Included AC adapter | Dimensions (WxDxH) | 48 mm x 135 mm x 165.8 mm | Weight | 950 g | Localisation | United Kingdom | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 4 TB |
Width | 48 mm |
Depth | 135 mm |
Height | 165.8 mm |
Weight | 950 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | WD SmartWare Pro (30 days trial) |
OS Required | Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 |
Miscellaneous | |
Cables Included | 1 x USB cable - external |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | Plug and Play, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
