ITEM | QTY | PRICE |
Philips B-Line 243B1 24" 1920x10...
4 | £970.08 |
Satechi Slim X1 Bluetooth Keyboard-UK
3 | £179.94 |
LG 43" UR7800 4K Ultra HD Smart TV
3 | £717.00 |
Data centers face growing pressures to store more with flat-to-shrinking budgets. Keeping systems operational for as long as possible to maximize investments can be an effective part of the strategy, but supporting those legacy applications becomes even more challenging as drive technologies move to next generation formats and interfaces. Ultrastar 7K2 has a SATA 6Gb/s interface and native 512-byte sector size to provide high performance and compatibility with legacy data center applications. Enhanced RAFF technology in the 7K2 includes sophisticated electronics to monitor the drive and correct both linear and rotational vibration disturbances in real time - especially helpful in multi-drive arrays and rack-mounted systems maintaining high read/write performance.
Product Description | WD Ultrastar DC HA210 HUS722T2TALA604 - hard drive - 2 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 2 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 7200 rpm | Features | Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), Dynamic fly height technology, advanced format 512n | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 640 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 2 TB |
Bytes per Sector | 512 |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 640 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 200 MBps |
Reliability | |
MTBF | 2,000,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 8.1 Watt (active) , 5.9 Watt (idle) |
Miscellaneous | |
Compliant Standards | RoHS 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 65 g @ 2 ms half-sine wave |
Shock Tolerance (non-operating) | 300 g @ 2 ms half-sine wave |
Vibration Tolerance (operating) | 1.08 g @ 10-300 Hz |
Vibration Tolerance (non-operating) | 3.8 g @ 10-300 Hz |
