WD RE® (Nearline Class Enterprise Drives)
Fast, reliable and enterprise-ready. Ideal for: Servers, video surveillance, and other demanding write-intensive applications,
WD RE4 7200 RPM Enterprise SATA hard drives offer massive capacity loaded with performance and reliability features ideal for servers, video surveillance, and other demanding write-intensive applications. With a designed, manufactured and demonstrated MTBF of 1.2 million hours at 100% duty cycle in nominal enterprise conditions, 64 MB cache, and best-in-class vibration tolerance, these drives are the ultimate in Enterprise SATA storage. Backed by a 5-year limited warranty.
Product Description | WD RE WD2000FYYZ - hard drive - 2 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 2 TB | Form Factor | 3.5" x 1/3H | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 64 MB | Spindle Speed | 7200 rpm | Features | Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, StableTrac, NoTouch ramp load technology, dual processor, Multi-axis shock sensor, Dynamic fly height technology, S.M.A.R.T. | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 700 g | Manufacturer Warranty | 5-year warranty | Designed For | My Cloud EX4 |
General | |
Device Type | Hard drive - internal |
Capacity | 2 TB |
Bytes per Sector | 512 |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 700 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 164 MBps |
Reliability | |
MTBF | 1,200,000 hours |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" x 1/3H |
Power | |
Power Consumption | 7.7 Watt (read) , 7.6 Watt (write) , 6.2 Watt (idle) , 9.1 Watt (active) |
Miscellaneous | |
Compliant Standards | RoHS, NMB-3 Class B, CAN ICES-3 Class B |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Shock Tolerance (operating) | 30 g @ 2 ms |
Shock Tolerance (non-operating) | 300 g @ 2 ms |
Sound Emission | 31 dBA |
Compatibility Information | |
Designed For | WD My Cloud EX4 |
