My Book® VelociRaptor™ Duo Dual-drive Storage System
The revolutionary Thunderbolt connector provides two channels of 10 Gb/s transfer rate in both directions, allowing data to travel both ways without compromising bandwidth. This means video files are imported faster, visual effects are rendered in record time and power through your projects.
Built with two 10,000 RPM WD VelociRaptor drives inside, My Book VelociRaptor Duo delivers extreme speed and high capacity to power through high-end video and photo editing, 3D renderings, graphic-intensive and more.
The dual Thunderbolt ports allow you to daisy chain more drive for more speed and higher capacity. Connect a Thunderbolt display and other Thunderbolt-enabled peripherals to achieve maximum efficiency and productivity.
The extreme SSD-like speed of two 10,000 RPM WD VelociRaptor drives united with the revolutionary speed of Thunderbolt technology help you complete your creative projects faster than ever. Daisy chain more drives for even more speed and higher capacity; then add peripherals to further enhance your productivity. Watch your productivity soar.
Product Description | WD My Book VelociRaptor Duo WDBUWZ0020JBK - hard drive array | Device Type | Hard drive array | Total Array Capacity | 2 TB | Interface | Thunderbolt | Installed Devices / Modules Qty | 2 (installed) / 2 (max) | Localisation | Middle East, Africa, Europe | Storage Controller | RAID RAID RAID 0, 1, JBOD | Hard Drive | 2 x 1 TB HDD | OS Required | Apple MacOS X 10.6.8 or later | Power | AC 120/230 V - 47/63 Hz | Dimensions (WxDxH) | 9.9 cm x 15.7 cm x 16.5 cm | Weight | 1.9 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 3-year warranty |
General | |
Chassis | |
Installed Devices / Modules Qty | 2 |
Supported Devices / Modules Qty | 2 |
Storage | |
HDD Array External Interface | Thunderbolt |
Storage Controller | |
Type | RAID |
RAID Level | RAID 0, RAID 1, JBOD |
Hard Drive | |
Type | HDD |
Capacity | 2 x 1 TB |
Spindle Speed | 10000 rpm |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 0 (free) x internal |
Interfaces | 2 x Thunderbolt |
System Requirements | |
Miscellaneous | |
Cables Included | 1 x Thunderbolt cable |
Software Included | WD Drive Utilities |
Compliant Standards | RoHS |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V - 47/63 Hz |
Dimensions & Weight | |
Width | 9.9 cm |
Depth | 15.7 cm |
Height | 16.5 cm |
Weight | 1.9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
The following resources are available for the WD 2TB My Book VelociRaptor Duo USB 3.0 10,000 RPM Thunderbolt
