My Passport Ultra delivers USB 3.0 performance and high capacity in a sleek design. It features WD SmartWare Pro automatic backup software for back up to the drive itself or to your Dropbox account. Secure your files with password protection and hardware encryption.
Product Description | WD My Passport Ultra WDBGPU0010BBL - hard drive - 1 TB - USB 3.0 | Type | Hard drive - external (portable) | Capacity | 1 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Features | Password authentication, automatic backup, NTFS formatted, cloud backup | Power Source | USB bus | Enclosure Colour | Noble blue | Dimensions (WxDxH) | 81.57 mm x 110.07 mm x 15.84 mm | Weight | 160 g | Localisation | Middle East, Africa, Europe | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 1 TB |
Width | 81.57 mm |
Depth | 110.07 mm |
Height | 15.84 mm |
Weight | 160 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Software & System Requirements | |
Software Included | WD Security, WD Drive Utilities |
OS Required | Apple MacOS X, Microsoft Windows Vista / 7 / 8 |
Miscellaneous | |
Cables Included | 1 x USB cable - external |
Compliant Standards | RoHS |
Package Type | Retail |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
