My Book® Studio™ desktop hard drive features blazing-fast USB 3.0 performance, massive capacity, compatibility with Apple® Time Machine® and password protection all in a a premium, aluminum enclosure that complements your Mac®.
Heat-dissipating, aluminum enclosure
Encased in a streamlined aluminum enclosure that remains cool to the touch, this drive complements your Mac, and as always, takes up minimal space on your desk.
Ultra-fast transfer rates
Save and access data at top speeds with the high-performance, USB 3.0 connectivity.
High capacity storage
With up to 1 TB capacity, there's plenty of room for all the chapters of your digital life.
Formatted HFS+ journaled
Works out of the box, with your Mac OS X 10.6.5 or later system. Can easily be reformatted to work with Windows® operating systems.
Password protection
Gain peace of mind knowing that your data is protected from unauthorized access with password protection and hardware-based encryption.
WD Drive Utilities™
Register your drive, run diagnostics and more using WD Drive Utilities.
Ideal For
Box Contents
Compatibility
Product Description | WD My Book Studio WDBCPZ0010HAL - hard drive - 1 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 1 TB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Features | Password authentication, built-in status LCD, Apple Time Machine compatible | Power Source | Included AC adapter | Dimensions (WxDxH) | 4.8 cm x 13.5 cm x 16.5 cm | Weight | 1.06 kg | Localisation | EMEA | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 1 TB |
Width | 4.8 cm |
Depth | 13.5 cm |
Height | 16.5 cm |
Weight | 1.06 kg |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | Smartware, WD Security, WD Drive Utilities |
OS Required | Microsoft Windows, Apple MacOS X 10.6.5 or later |
Miscellaneous | |
Cables Included | 1 x USB cable - external |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | RoHS |
Package Type | Retail |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
The following resources are available for the WD 1TB My Book Studio Mac USB 3.0 Desktop Hard Drive
