ITEM | QTY | PRICE |
HP LaserJet Pro M501dn
4 | £1,557.84 |
Asus VivoBook 14 Intel Core i5-1135G7...
2 | £1,229.32 |
The WD Gold is a highly reliable solution for demanding storage environments. Specifically designed for use in enterprise-class storage systems and data centers, the WD Gold Enterprise Class SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
Product Description | WD Gold WD161KRYZ - hard drive - 16 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 16 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 512 MB | Spindle Speed | 7200 rpm | Features | Vibration dampening, HelioSeal, 24x7 continuous operation, advanced format 512e, Energy-Assisted Magnetic Recording (EAMR), Triple State Actuator (TSA) | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 690 g | Localisation | Worldwide | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 16 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 690 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 262 MBps |
Reliability | |
MTBF | 2,500,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 6.5 Watt (active) , 5.6 Watt (idle) |
Miscellaneous | |
Compliant Standards | RoHS 2011/65/EU |
Dimensions & Weight (Shipping) | |
Shipping Width | 12.7 cm |
Shipping Depth | 6.35 cm |
Shipping Height | 19.05 cm |
Shipping Weight | 830 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 50 g @ 2 ms half-sine wave |
Shock Tolerance (non-operating) | 250 g @ 2 ms half-sine wave |
