Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
Product Description | WD Black Performance Hard Drive WD1600BEKX - hard drive - 160 GB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 160 GB | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 16 MB | Spindle Speed | 7200 rpm | Features | NoTouch ramp load technology, dual processor, S.M.A.R.T. | Dimensions (WxDxH) | 69.85 mm x 100.2 mm x 9.5 mm | Weight | 106 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 160 GB |
Width | 69.85 mm |
Depth | 100.2 mm |
Height | 9.5 mm |
Weight | 106 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 115 MBps |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Start / Stop Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 8 - 95% (non-condensing) |
