The VFS-002M is Mac compatible and comes with 35mm & 110mm slide and negative trays. Convert your old memories onto your PC ready for editing, archiving, restoring or printing.
Transfer your old 35mm negative film and slides and 110mm instamatic negatives onto your PC/Notebook/Mac ready for editing, archiving or printing. A simple plug and play scanner with no driver to install and fast one touch scanning making it easy to bring those old pictures back to life. Perfect for restoring all those old cherished memories and moments back into the digital world and sharing by email or Facebook. If you want to remove redeye or enhance your image in anyway then simply use the bundled Arcsoft Mediaimpressions software. This is the first scanner to be capable of scanning 110mm negatives.
Product Description | Veho VFS-002M Colourbright - film scanner (35 mm) - desktop - USB 2.0 | Device Type | Film scanner (35 mm) - desktop | Interface Type | USB 2.0 | Scanning Sensor Type | CMOS | Max Supported Document Size | Film 135 (35mm) | Grayscale / Color Depth | 48-bit colour | Grayscale / Color Depth (External) | 24-bit (16.7 million colours) | Optical Resolution | 1400 dpi | Interpolated Resolution | 1800 dpi x 3600 dpi | Supported Document Type | Slides, film | System Requirements | Microsoft Windows XP, Apple MacOS X 10.3.4 or later, Microsoft Windows Vista (32/64 bits) | Dimensions (WxDxH) | 9.3 cm x 7.7 cm x 10 cm |
General | |
Scanner | |
Colour Depth | 48-bit colour |
Colour Depth (External) | 24-bit (16.7 million colours) |
Scanner Features | Powered by USB port |
Media Handling | |
Expansion / Connectivity | |
Interfaces | USB 2.0 |
Miscellaneous | |
Compliant Standards | Plug and Play |
Software / System Requirements | |
Software Included | ArcSoft MediaImpression |
OS Required | Microsoft Windows XP, Apple MacOS X 10.3.4 or later, Microsoft Windows Vista (32/64 bits) |
Dimensions & Weight | |
Width | 9.3 cm |
Depth | 7.7 cm |
Height | 10 cm |
