The super tiny Muvi Atom redefines the world of small.
The Muvi Atom tiny size does not compromise quality recording at 640 x 480 at 30 FPS using Frame Rate Enhancement technology. The Atom also introduces the ability to take photo snapshots at 280 x 960 and comes bundled with the 2GB Micro SD card and sports mounting kit.
Product Description | Veho muvi Atom - No Proof No Glory - camcorder - storage: flash card | Product Type | Camcorder | Media Type | Flash card | Memory Card Slot | microSD card | Sensor Resolution | 2.0 MP | Focus Adjustment | Focus free | Supported Battery | Li-ion rechargeable battery (included) | Colour | Black | Dimensions (WxDxH) | 2 cm x 1.9 cm x 4 cm |
General | |
Enclosure Colour | Black |
Camcorder Type | Consumer |
Camcorder Sensor Resolution | 2.0 MP |
Sensor Qty | 1 CMOS |
Camcorder Media Type | Flash card |
Optical Sensor Type | CMOS |
Exposure & White Balance | |
Exposure Modes | Programme, automatic |
Lens System | |
Max View Angle | 80 degree(s) |
Additional Features | |
Additional Features | Audio recording, auto power save, USB charging |
Microphone | |
Microphone Operation Mode | Mono |
Connections | |
Connector Type | USB |
Software | |
Software | Drivers & Utilities |
Miscellaneous | |
Included Accessories | Neck strap, mounting hardware, carrying pouch, USB cable, spring clip, underwater housing, helmet mounting kit, magnet mount, handle bar mount |
Underwater Use | Yes |
Underwater Depth | Up to 30 m |
Battery | |
Battery Type | Lithium Ion - manufacturer-specific |
Details | Li-ion rechargeable battery (included) |
Memory / Storage | |
Supported Memory Cards | microSD Card, microSDHC Card |
Memory Card | 4 GB microSDHC |
Image Storage | JPEG 1280 x 960 |
Video Capture | 640 x 480 - 30 fps |
Dimensions & Weight | |
Width | 2 cm |
Depth | 1.9 cm |
Height | 4 cm |
