With 2.4" LCD color screen and built in Lith-ion battery this scanner has true 'stand alone' capability. It also allows you to scan 110 negatives as well as the usual 35mm.
Product Description | Veho VFS-008 Smartfix - film scanner (35 mm) - desktop - USB 2.0 | Device Type | Film scanner (35 mm) - desktop | Interface Type | USB 2.0 | Scanning Sensor Type | CMOS | Max Supported Document Size | Film 135 (35mm) | Interpolated Resolution | 3600 dpi | Supported Document Type | Slides, film | Battery | 1 x Lithium Ion | System Requirements | Apple MacOS, Microsoft Windows 2000/XP/Vista/7 | Dimensions (WxDxH) | 10 cm x 10 cm x 15 cm | Manufacturer Warranty | 1-year warranty |
General | |
Scanner | |
Scanner Features | Powered by USB port, 2.4" LCD screen |
Media Handling | |
Memory | |
Supported Flash Memory Cards | SD Memory Card |
Expansion / Connectivity | |
Interfaces | USB 2.0 |
Miscellaneous | |
Included Accessories | Slide holder, 2 GB SD Memory Card, 2 film holders |
Compliant Standards | RoHS |
Battery | |
Battery Installed | 1 x Lithium Ion |
Software / System Requirements | |
OS Required | Apple MacOS, Microsoft Windows 2000/XP/Vista/7 |
Dimensions & Weight | |
Width | 10 cm |
Depth | 10 cm |
Height | 15 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
