BT.com
Wishlist
TRENDnet TEW-824DRU AC1750 Dual Band Wireless Router with StreamBoost
TRENDnet TEW-824DRU AC1750 Dual...
£99.27
£99.27
Add to wishlist
Delivery
Standard 1-3 working days
TRENDnet’s AC1750 Dual Band Wireless Router with StreamBoost™ Technology, model TEW-824DRU, is built to perform in a busy connected home. It generates two concurrent WiFi networks—a 1,300 Mbps WiFi AC and a 450 Mbps WiFi N network. Qualcomm® StreamBoost™ technology prioritizes low latency gaming and voice streams, shapes network traffic to optimize each connected experience, and graphically displays all connected device/application traffic. Use the Gigabit Ethernet ports and USB share port to further extend an extreme performance digital network.
Optimized Gaming
StreamBoost™ minimizes latency for gaming, video, and voice streams to eliminate stutter and lag caused by high bandwidth traffic such as torrents.
Built For Busy Homes
Concurrent extreme WiFi networks and all Gigabit ports seamlessly network connected devices and high bandwidth streams such as 4K video.
Network Protection Tools
TRENDnet includes tools to help protect your home network including parental controls, isolated guest networks, and pre-encrypted WiFi.
Optimized Gaming
When latency is the difference between winning and losing, Streamboost has your back. It helps eliminate hated stutter and lag with a laser focus on providing the lowest latency possible. When high bandwidth traffic is killing other networks, Streamboost thrives by prioritizing gaming, video, and voice over other non-critical data streams.
Traffic Shaping
StreamBoost dynamically shapes network traffic, delivering an optimized user experience, as applications and devices become active. Out of the Box, Streamboost automatically identifies, classifies, and intelligently manages all traffic. No user management is required. However, users can choose to manually override default device priority.
App + Device Aware
With more devices and applications downloading, streaming, and playing than ever before, today's home network needs a smarter way to deliver the best online experience. StreamBoost does just that. Constant updates provide the ability to identify new-to-market applications and devices and maintain an optimized experience as your home network changes.
Traffic Mapping
See your smart phones, tablets, computers, game consoles, and all other connected devices graphically mapped with their respective upload and download bandwidth usage. Select a device such as your computer to see detailed network loading of all of its applications and programs. This powerful network map feature is a great troubleshooting tool.
Easy Setup
Get up and running in minutes with the intuitive guided setup
Simultaneous AC1750 Dual Band
Concurrent high performance 1,300 Mbps WiFi AC + 450 Mbps WiFi N bands
Qualcomm® StreamBoost™ Latency Prioritization
StreamBoost™ prioritizes latency for gaming and voice streams to eliminate stutter or lag caused by other high bandwidth network traffic such as torrent downloads
Qualcomm® StreamBoost™ Traffic Shaping
StreamBoost™ intelligently allocates the optimal amount of bandwidth for each individual device/application and users can further manually assign device priority
Device/Traffic Mapping
See all connected network devices/applications and their respective real-time network usage and review historical usage data
Pre-Encrypted Wireless
For your convenience the WiFi is pre-encrypted with its own unique password
Wireless Coverage
High performance amplifiers maximize wireless coverage
Gigabit Ports
Gigabit ports support high performance wired connections
USB Share Port
Share content across the network with the USB share port
Guest Network
Create an isolated network for guest internet access only
Parental Controls
Control access to specific websites or types of content
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Targeted Beamforming
Increased real-time performance by directing stronger wireless signals to your specific location
Backward Compatible
Compatible with legacy wireless devices
Energy Savings
Embedded GREENnet technology reduces power consumption
TRENDnet TEW-824DRU - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, CSMA/CA, DDNS, DHCPv6
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
TFTP
VoIP Protocols
H.323, SIP
NAT support, Stateful Packet Inspection (SPI), ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, IP address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, virtual server support, iTunes server, Wi-Fi Protected Setup (WPS), Samba support, FTP server, BitTorrent Client, reset button, StreamBoost
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac
AC 120/230 V ( 50/60 Hz )
15.1 cm x 7.2 cm x 19.1 cm
408 g
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Routing Protocol
TFTP
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac , FCC
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
IP Telephony
VoIP Protocols
H.323, SIP
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
18 Watt
1 x network cable - 1.5 m
15.1 cm
7.2 cm
19.1 cm
408 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Scroll to top
