UP525 - 25W 5-Port USB Charger
Reduce the number of chargers
If you’ re going away you will need to pack only 1 box and 5 cables, rather than 5 original chargers.
Condense the charging time and space
By charging all 5 devices from 1 power outlet at once, you will free up additional power outlets.
Elegant round shape design
Provides more room between each USB port so you can easily plug in your devices to charge.
Charge 65% Faster, Save Up to 40% Charging Time
TP-LINK Smart Charging technology identifies the connected devices and delivers the possible max output, together with 5V/2.4A ultra fast charging speed, UP525 can charge 65% faster and save up to 40% charging time. Fully charging iPhone 6s Plus takes 2.4 hours with TP-LINK Smart Charging, while 4.2 hours with an original Apple charger.
Optimization for all devices
Compatible with smart devices running iOS, Android, Windows and most other USB-charged devices, from devices with large battery like tablets, to gadgets with tiny batteries like smart wearable devices.
5 Flexible Output Ports
Powered by TP-LINK Smart Charging technology, all outputs ports of UP525 can intelligently adjust the charging power subject to the connected devices. These flexible output ports are designed to be capable of delivering full speed charging power for devices with large battery like tablets, and also capable of delivering and minimal charging power for gadgets with tiny battery like smart wearable devices.
Product Description | TP-Link UP525 power adapter - USB - 25 Watt | Product Type | Power adapter | Dimensions (WxDxH) | 9.64 cm x 9.64 cm x 2.86 cm | Output Connector Type | Total 5: USB | Voltage Required | AC 100-240 V | Voltage Provided | 5 V | Max Electric Current | 5 A | Power Provided | 25 Watt |
General | |
Designed For | Portable player, tablet, mobile phone |
Width | 9.64 cm |
Depth | 9.64 cm |
Height | 2.86 cm |
Power Device | |
Output connectors | Total 5: 4 pin USB Type A |
Features | Short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, Smart Charge Technology, automatic charge detection |
