The TL-WA855RE connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own. Featuring two external antennas with MIMO technology, the TL-WA855RE boosts speeds and increases efficiency throughout the network.
Product Description | TP-Link TL-WA855RE 300Mbps Mini Wireless N Range Extender - Wi-Fi range extender - Wi-Fi | Device Type | Wi-Fi range extender | Form Factor | External | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz | OS Required | UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7, Windows 8 / 8.1, Windows 10 | Dimensions (WxDxH) | 5.2 cm x 3.4 cm x 6.5 cm |
General | |
Width | 5.2 cm |
Depth | 3.4 cm |
Height | 6.5 cm |
Networking | |
Connectivity Technology | Wireless, wired |
Data Transfer Rate | 300 Mbps |
Status Indicators | Signal strength |
Features | MIMO technology, Wi-Fi Protected Setup (WPS), reset button |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Aerial | |
Antenna | External integrated |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 100Base-TX - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 3 Watt |
Software / System Requirements | |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
