TL-SG1008P is easy to install and use. It requires no configuration and installation. With desktop design, outstanding performance and quality, the TP-LINK TL-SG1008P 8-port gigabit desktop switch with 4-port PoE is a great selection for expanding your home or office network.
Product Description | TP-Link TL-SG1008P - switch - 8 ports - unmanaged | Device Type | Switch - 8 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 4 x 10/100/1000 (PoE) + 4 x 10/100/1000 | Power Over Ethernet (PoE) | PoE | MAC Address Table Size | 1K entries | Features | Flow control, full duplex capability, PoE, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x | Power | (50/60 Hz) | Dimensions (WxDxH) | 17.1 cm x 9.8 cm x 2.7 cm |
General | |
Enclosure Type | Desktop |
Status Indicators | Power, link/activity |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE |
Power | |
Power Device | External power adapter |
Voltage Required | (50/60 Hz) |
Miscellaneous | |
Compliant Standards | FCC |
Dimensions & Weight | |
Width | 17.1 cm |
Depth | 9.8 cm |
Height | 2.7 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
