We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Tp-Link Tapo Mini Smart Wi-Fi plug with Energy monitoring
Matter Certified Integrate Matter-certified Tapo devices with other Matter end products into your preferred ecosystem Energy Monitoring - Set your electricity rate to estimate your energy bills offers more comprehensive insights into home appliances' power consumption with more intuitive and straightforward data visualizations Note: Energy Monitoring feature is not supported by Matter yet but coming soon. Please use this feature in the Tapo app for now Compact Design - Mini-sized to avoid blocking adjacent outlets Voice Control Manage your smart plug with voice commands via Amazon Alexa Apple Siri or Google Assistant
Product Description | Tapo P110M V1 - smart plug - Bluetooth, 802.11b/g/n | Product Type | Smart plug | Environment | Indoor | Functions | Energy use monitor, remote control | Power Source | Power socket | Intelligent Assistant | Siri, Google Assistant, Alexa - indirect | Connectivity | Wireless - Bluetooth, 802.11b/g/n | Frequency Band | 2.4 Ghz | Manufacturer Warranty | 2-year warranty | Dimensions (WxDxH) | 5.15 cm x 3.06 cm x 7.25 cm |
General | |
Connectivity Technology | Wireless - Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Features | Up to 3680 Watt, Away Mode, voice control, LED indicator, timer, overload protection, flame-retardant, automatic switch-off function, 16 A max load current, schedule function, rust proof, child safety shutter Bluetooth for onboarding only, Matter compatibility |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Compatible Application | Tapo app |
Communications Type | Cloud |
Communications Technology | Wi-Fi |
Intelligent Assistant | Siri, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Polycarbonate |
Encryption Algorithm | WPA-PSK, WPA2-PSK, WEP, WPA3 |
Voltage Required | AC 100-240 V |
Rated Current | 13 A |
Compliant Standards | RoHS, UL 94 V-0, UKCA |
Dimensions & Weight | |
Width | 5.15 cm |
Depth | 3.06 cm |
Height | 7.25 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% RH (non-condensing) |
