TP-LINK's N600 Wireless Dual Band PCI Express Adapter, TL-WDN3800 allows you to connect a desktop computer to a wireless network and access a high-speed wireless network connection. Complying with IEEE 802.11 a/b/g/n, the device can use the 2.4 GHz or 5 GHz channels and provide wireless speeds of up to 300 Mbps which is ideal for users seeking a highly robust, bandwidth intensive wireless networking experience, particularly with HD video streaming and online gaming.
Product Description | TP-Link TL-WDN3800 - network adapter - PCIe | Device Type | Network adapter | Form Factor | Plug-in card | Interface (Bus) Type | PCI Express x1 | Data Link Protocol | 802.11a, 802.11b/g/n | Data Transfer Rate | 300 Mbps | Frequency Band | 2.4 GHz, 5 GHz | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n | System Requirements | Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) |
General | |
Networking | |
Connectivity Technology | Wireless |
Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n |
Line Coding Format | DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM |
Features | Ad-Hoc Mode |
Aerial | |
Antenna | External detachable |
Antenna Qty | 2 |
Directivity | Omni-directional |
Gain Level | 2 dBi |
Expansion / Connectivity | |
Interfaces | 2 x aerial - RP-SMA |
Compatible Slots | 1 x PCI Express x1 |
Miscellaneous | |
Encryption Algorithm | AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
