300Mbps Wireless N Router TL-WR940N is a combined wired/wireless network connection device designed specifically for small business and home office networking requirements. With MIMO Technology, TL-WR940N creates an exceptional and advanced wireless performance, making it ideal for streaming HD video, making VoIP and online gaming. Also, Quick Setup Security (QSS) button on the sleek and fashionable exterior ensures WPA2 encryptions, preventing the network from outside intrusions.
Product Description | TP-Link TL-WR940N - v3 - wireless router - Wi-Fi - desktop | Device Type | Wireless router - 4-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz | Data Transfer Rate | 450 Mbps | Network / Transport Protocol | TCP/IP, ICMP/IP, PPPoE | Features | Firewall protection, DMZ port, DHCP support, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, SNTP support, MIMO technology, virtual server support | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n | Dimensions (WxDxH) | 20 cm x 14 cm x 2.8 cm |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2, WPA-PSK, WPA2-PSK, WEP |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, FCC, RoHS |
Status Indicators | Port status, power |
Expansion / Connectivity | |
Interfaces | LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 |
Aerial | |
Aerial | External integrated |
Antenna Qty | 3 |
Directivity | Omni-directional |
Gain Level | 3 dBi |
Power | |
Power Device | External power adapter |
Dimensions & Weight | |
Width | 20 cm |
Depth | 14 cm |
Height | 2.8 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
