TP LINK 150Mbps wireless N Nano USB adapter
£7.99
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Wireless N speed up to 150 Mbps
  • Supports WMM standard for better streaming of real-time data such as video, music, video chat
  • Supports software based WPS
  • Supports soft AP function for wireless Internet sharing
  • Advanced security - supports 64/128 WEP, WPA/WPA2, WPA-PSK/WPA2-PSK, supports IEEE 802.1x
  • Seamlessly compatible with 802.11b/g/n products
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11g, 802.11g + 2 more
  • Form Factor: Plug-in module
  • Compatibility: PC
  • Type: Network adapter, Adapters
Product codes
chevron icon
chevron icon
TP-LINK's 150Mbps wireless N Nano USB adapter, TL-WN725N allows users to connect a desktop or notebook computer to a wireless network at 150Mbps. This miniature adapter is designed to be as convenient as possible and once connected to a computer's USB port, can be left there, whether traveling or at home. It also features advanced wireless encryption and easy installation.
Miniature Design - Plug in and forget
With its miniature size and sleek design, users can connect the nano adapter to any USB port and leave it there. There's no need to worry about blocking adjacent USB interfaces or that the adapter may fall out when moving a connected laptop from A to B, with the tiny device flush against the USB port.
150Mbps Wireless N Speed - Stable Wireless Signals
The TL-WN725N complies with wireless 802.11 b/g/n standards, with transmission data rates of up to 150Mbps enabling fast wireless connections for lag-free online gaming and video streaming.
WPA / WPA2 Encryptions - Advanced Security
When speaking about wireless security, WEP encryptions are no longer the strongest and safest protections against intrusions. The TL-WN725N provides WPA/WPA2 encryptions created by the WI-FI Alliance™, promoting interoperability and security for WLAN, which effectively and efficiently protects users' wireless networks.
Bundled CD for Easy Operation
The TL-WN725N comes with a 14-language utility located on its bundled CD that helps users complete the software installation and wireless network settings, including security configurations and wireless connections, quickly and easily, even for novice users new to wireless networking.
chevron icon
Product Description TP-LINK TL-WN725N Nano Wireless USB Adapter - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type Hi-Speed USB
Dimensions (WxDxH) 1.86 cm x 1.5 cm x 0.71 cm
Weight 2.1 g
Data Link Protocol IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate 150 Mbps
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, USB 2.0, IEEE 802.11n
System Requirements Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions)
Manufacturer Warranty 2 years warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£7.99
