Give your business an edge with an enterprise-class laptop built for small- or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R40 will help meet all your computing needs without putting a big dent in your bottom line. Powered by a fast and smooth processor you will be able to more effectively manage your workload wherever the day takes you. Plus, enjoy added security knowing that your Satellite Pro R40 is extra strong thanks to its durable design. Imagine how much more pleasant those spreadsheets will be on a brilliant display. The keyboard with a numeric keypad will make multi-tasking more convenient, plus, there is a host of other components to be effective - like plenty of memory a built-in optical drive, a huge storage, business ports and much more.
Product Description | Dynabook Toshiba Satellite Pro R40-C-13K - 14" - Intel Core i3 - 6006U - 4 GB RAM - 128 GB SSD | Product Type | Notebook | Operating System | Windows 10 Home | Processor | Intel Core i3 (6th Gen) - 6006U / 2 GHz / 3 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 128 GB SSD | Optical Drive | DVD SuperMulti | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 520 | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 4-cell - up to 8 hours | Features | 3D sensor | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Graphite black | Dimensions (WxDxH) | 34.01 cm x 24.41 cm x 2.38 cm | Weight | 1.75 kg | Localisation | Region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | EMEA warranty - 1 year - carry-in |
General | |
Processor / Chipset | |
CPU | Intel Core i3 (6th Gen) 6006U / 2 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 8 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD |
Optical Drive | DVD±RW (±R DL) / DVD-RAM |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Anti-reflective |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - 1280 x 720 |
Resolution | 0.9 Megapixel |
Sound | Stereo speakers, two microphones |
Compliant Standards | DTS Studio Sound |
Input | |
Type | Keyboard, touchpad |
Features | Multi-gesture touch pad, Palm Rejection Technology |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 3165 |
Network Interface | Gigabit Ethernet |
Features | Intel Wireless Display (WiDi) |
Compliant Standards | Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell Lithium Ion |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 100/240 V (50 - 60 Hz) |
Output | 19 V, 2.37 A |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack , USB 3.0 (Sleep & Charge) |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card) |
Software | |
Software Included | Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days trial) |
Miscellaneous | |
Integrated Options | 3D sensor |
Features | Administrator password, system password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.75 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | EMEA warranty - 1 year - carry-in |
