The 15.6" Satellite Pro C850 is the perfect option for businesses looking for a combination of quality and leading value. It features a thinner textured matt black design that prevents unwanted fingerprints on the lid, keyboard and palm-rest. Extensive connectivity options are incorporated and include SuperSpeed USB 3.0, HDMI and an integrated numeric keypad for added convenience and ease of use.
Product Description | Dynabook Toshiba Satellite Pro C850-1LV - 15.6" - Intel Core i3 2348M - 4 GB RAM - 500 GB HDD | Product Type | Notebook | Operating System | Win 7 Pro 64-bit | Processor | Intel Core i3 (2nd Gen) 2348M / 2.3 GHz / 3 MB Cache | Memory | 4 GB DDR3 (1 x 4 GB) | Storage | 500 GB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 3000 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet | Battery | Up to 5.5 hours | Colour | Matt black with textured pattern, black keyboard | Dimensions (WxDxH) | 38 cm x 24.2 cm x 3.352 cm | Weight | 2.3 kg | Microsoft Office Preloaded | Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC. | Localisation | Region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | EMEA warranty - 1 year - carry-in |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i3 (2nd Gen) 2348M / 2.3 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Features | Enhanced SpeedStep technology |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 8 GB |
Technology | DDR3 SDRAM |
Speed | 1333 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA 3Gb/s / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM |
Read Speed | 24x (CD) / 8x (DVD) |
Write Speed | 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) |
CD / DVD Rewrite Speed | 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HighBrightness, anti-reflective |
Audio & Video | |
Graphics Processor | Intel HD Graphics 3000 |
Max Allocated RAM Size | 1696 MB |
Camera | Yes |
Resolution | 1 Megapixel |
Video Resolutions | 1280 x 800 |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC269Q |
Compliant Standards | High Definition Audio, SRS Premium Sound HD |
Input | |
Type | Keyboard, touchpad |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n, Bluetooth 4.0 |
Wireless Controller | Atheros WB222 |
Network Interface | Gigabit Ethernet |
Compliant Standards | Wi-Fi CERTIFIED |
Battery | |
Technology | Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 5.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19 V, 3.42 A |
Connections & Expansion | |
Interfaces | USB 3.0 , LAN , VGA , Headphone output , HDMI , 2 x USB 2.0 , Microphone input |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | Toshiba TEMPRO Performance Tuning Service, McAfee Internet Security Suite (30 days subscription), Toshiba Supervisor Password Utility, Skype, Toshiba Assist, Windows Live Essentials, Toshiba PC Health Monitor, Toshiba Recovery Media Creator, Toshiba Eco Utility, Toshiba Service Station, Microsoft Office 2010 Starter, Toshiba HDD/SSD Alert, Toshiba Resolution+, Nero Kwik Media, Nero BackItUp & Burn Autobackup, Windows 8 Pro 64-bit (DVD) |
Miscellaneous | |
Case Material | Polycarbonate ABS |
Features | Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.3 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | EMEA warranty - 1 year - carry-in |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 90% |
