With an ultra-thin, premium design the high-performance Toshiba Portégé Z30-A Ultrabook was made to keep business moving. A long-lasting battery and Intel Core i5 processor for Ultrabook will help you power through the working day while the ultra-light form and full-size ports give you all the flexibility you need on the go. The Z30-A's durable magnesium chassis has been rigorously drop- and spill-tested and also comes with high-level security and manageability technologies.
Product Description | Dynabook Toshiba Portégé Z30-A-1GX - 13.3" - Intel Core i5 - 4210U - 8 GB RAM - 256 GB SSD | Product Type | Ultrabook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence | Processor | Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache | Memory | 8 GB DDR3L (1 x 8 GB) | Storage | 256 GB SSD | Display | 13.3" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 4400 | Input Device | DualPoint | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 4-cell - up to 10 hours | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader | Colour | Steel gray metallic, matte black keyboard | Dimensions (WxDxH) | 31.6 cm x 22.7 cm x 1.79 cm | Weight | 1.2 kg | Localisation | Region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | EMEA warranty - 1 year - carry-in |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence |
Processor / Chipset | |
CPU | Intel Core i5 (4th Gen) 4210U / 1.7 GHz |
Max Turbo Speed | 2.7 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Features | Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD mSATA SATA 3Gb/s |
Display | |
Type | 13.3" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HighBrightness, anti-reflective |
Audio & Video | |
Graphics Processor | Intel HD Graphics 4400 |
Camera | Yes - Full HD |
Resolution | 2 Megapixel |
Sound | Stereo speakers, microphone |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Input | |
Type | Keyboard, DualPoint |
Features | Spill-resistant, multi-touch clickpad |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 3160 |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I218-V |
Features | Intel Wireless Display (WiDi), Wake-on-LAN (WOL) |
Compliant Standards | Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell lithium polymer |
Capacity | 52 Wh |
Run Time | Up to 10 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V, 2.37 A |
Connections & Expansion | |
Interfaces | LAN , VGA , HDMI , 3 x USB 3.0 , Headphone/microphone combo jack , Dock |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD) |
Miscellaneous | |
Case Material | Magnesium alloy |
Dockable | Yes |
Features | Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, USB Sleep-and-charge ports |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.2 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | EMEA warranty - 1 year - carry-in |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Shock Tolerance (operating) | 10 g |
Shock Tolerance (non-operating) | 60 g |
Vibration Tolerance (operating) | 0.5 g |
Vibration Tolerance (non-operating) | 1 g |
