The Portégé Z30-C was made to move. Ultra-light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get many hours on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective screen with LED backlighting.
With the advanced processor your laptop has all the power you need to multitask on the move or in the office. The Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster. The ultra-durable Portégé Z30-C was designed to withstand the pressures of professional life and meet Toshiba's quality standards.
Product Description | Dynabook Toshiba Portégé Z30-C-125 - 13.3" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD | Product Type | Ultrabook | Operating System | Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence | Processor | Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache | Memory | 8 GB DDR3L (1 x 8 GB) | Storage | 256 GB SSD | Display | 13.3" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 520 | Input Device | DualPoint | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 4-cell - up to 11 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Steel gray metallic, matte black keyboard | Dimensions (WxDxH) | 31.6 cm x 22.7 cm x 1.79 cm | Weight | 1.2 kg | Localisation | Region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | International warranty - 1 year - carry-in |
General | |
Operating System | Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6500U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 4 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD SATA |
Display | |
Type | 13.3" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HighBrightness, anti-reflective |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - Full HD |
Resolution | 2 Megapixel |
Sound | Stereo speakers, stereo microphone |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Input | |
Type | Keyboard, DualPoint |
Features | Multi-touch clickpad |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 8260 |
Network Interface | Gigabit Ethernet |
Features | Intel Wireless Display (WiDi) |
Compliant Standards | Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell lithium polymer |
Run Time | Up to 11 hours |
AC Adapter | |
Input | AC 120/230 V |
Output | 19 V, 2.37 A |
Connections & Expansion | |
Interfaces Details | 3 x USB 3.0 , HDMI , VGA , Headphone/microphone combo jack , LAN , Dock |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD) |
Miscellaneous | |
Case Material | Magnesium alloy |
Dockable | Yes |
Features | Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, USB Sleep-and-charge ports |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.2 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | International warranty - 1 year - carry-in |
