Toshiba E300 2TB 3.5" 5700RPM 64MB Cache Low Energy Internal HDD
Key features
  • Everyday storage
  • Performance alongside efficiency
  • Low power consumption
  • Low temperature, low noise
  • Advanced read and write technology
  • Keep data secure
Product codes
chevron icon
chevron icon
The quiet, low-energy eco model
Ideal for Reliability and Extended Use
2TB
5700rpm
64MB Buffer
Silent Design
Built-in silent operation technology introduces a new dimension of silent design.
Efficient Power Management
Energy consumption is reduced by 19 to 25% compared to 7,200-rpm models. Low temperature operation, curbing heat generation, raises reliability throughout the HDD service life.
Eco-Friendly Performance
Incorporating keen concern for the environment, there is full compliance with the ROHS directive defining Restriction of Hazardous Substances. For chlorine and bromine, monitoring holds concentrations within the voluntary standard values (900 ppm for each substance, combined ceiling of 1,500 ppm). The demand for alogen free operation is also addressed, yet another measure with ecology foremost in mind.
chevron icon
Product Description Toshiba E300 - hard drive - 2 TB - SATA 6Gb/s
Type Hard drive - internal
Capacity 2 TB
Form Factor 3.5" x 1/3H
Interface SATA 6Gb/s
Buffer Size 64 MB
Spindle Speed 5700 rpm
Features RV Sensor, shock sensor, Native Command Queuing (NCQ), Halogen Free, Tunnel Magneto-resistive Recording (TMR) Head Technology, Ramp Load, Perpendicular Magnetic Recording (PMR), Advanced Format technology, Dual Stage Actuator (DSA)
Dimensions (WxDxH) 101.6 mm x 147 mm x 26.1 mm
Weight 680 g
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
