We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Toshiba’s N300 3.5-inch internal hard disk offers unprecedented reliability for NAS and other high-performance storage systems. It is optimized to meet the reliability, endurance, performance and scalability requirements of 24-hour x 7-day high-capacity storage for personal, home office and small business use. The N300 is available in capacities of up to 8 TB.
Use for:
• Up to 8-bay NAS
• Desktop RAID and servers
• Multimedia server storage
Optimised for use in 1-8 bay NAS enclosures
3.5" SATA hard drive
7200 rpm / 128 MB buffer
Product Description | Toshiba N300 NAS - hard drive - 8 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 8 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 7200 rpm | Features | Shock sensor, NAS compatible, 24x7 continuous operation, vibration sensor, workload up to 180 TB per year | Dimensions (WxDxH) | 101.85 mm x 147 mm x 26.1 mm | Weight | 770 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 8 TB |
Width | 101.85 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 770 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 241 MBps |
Reliability | |
MTBF | 1,000,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^14 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Miscellaneous | |
Compliant Standards | RoHS |
Package Type | Bulk |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 65 °C |
