The ideal choice for when space is limited, the 32DV504 is an LCD TV with a built-in DVD player offering the reassurance of Toshiba quality and all-in-one convenience. It features stunning high definition image quality and built-in Freeview digital TV, for access to up to 50 digital TV channels and 24 radio stations without subscription.
Multiple HDMI inputs let you connect all your digital devices to this TV, with USB connectivity enabling you to enjoy videos, photos and music from USB drive directly via the TV.
Product Description | Toshiba 32DV504B REGZA DV Series - 32" LCD TV - HD - for hotel / hospitality | Product Type | LCD TV with built-in DVD player | Diagonal Class | 32" | Commercial Use | Hotel / hospitality | Resolution | 1366 x 768 | Display Format | 720p | Video Interface | Component, composite, HDMI, SCART | HDMI Ports Qty | 2 ports | PC Interface | VGA (HD-15) | HDCP Compatible | Yes | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Analogue TV Tuner | PAL, SECAM | Settings Cloning Capability | Yes | Sound Output Mode | Stereo | Speaker System | 2 speakers | Stereo Reception System | NICAM | DVD | DVD player - built-in | USB | Yes | Energy Class | Class C | Power Consumption Operational | 79.8 Watt | Power Consumption Stand by | 0.3 Watt | Dimensions (WxDxH) - with stand | 78.8 cm x 20.5 cm x 55.7 cm | Weight | 11.5 kg |
General | |
Product Type | LCD TV |
Combined With | Built-in DVD player |
Series | REGZA DV Series |
TV Tuner Presence | Yes |
Modes | Game mode, hotel mode |
Dimensions | With stand |
Width | 78.8 cm |
Depth | 20.5 cm |
Height | 55.7 cm |
Weight | 11.5 kg |
Display | |
Dynamic Contrast Ratio | 100000:1 |
Brightness | 450 cd/m² |
Widescreen Modes | Conventional 4:3 |
Viewing Angle | 178 degrees |
Viewing Angle (Vertical) | 178 degrees |
Response Time | 8 ms |
Max V-Sync Rate | 50 Hz |
Comb Filter | 3D digital |
Colour Temperature Control | Yes |
Features | Audio Description (AD), Automatic Format Detection (AFD), 3D Color Management, Digital Noise Reduction (DNR), MPEG Noise Reduction, Automatic Channel Install (ACI) |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
DVD | |
Type | DVD player - built-in |
Media Type | DVD-R, DVD-RW, DVD, CD |
Features | JPEG photo playback, MP3 playback |
TV Tuner | |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | FREEVIEW |
Digital Channel Qty | 800 channels |
Video Features | |
Analogue Video Input Signals | NTSC, PAL, SECAM |
Teletext | Yes |
Teletext Memory | 1000 pages |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 1 |
Radio | |
Preset Station Qty | 24 channels |
Audio System | |
Output Power / Total | 12 Watt |
Speakers | 2 x main channel speaker - 6 Watt |
Connections | |
Connector Type | 2 x HDMI , VGA / component video input , Composite video input , SCART , USB , SPDIF output , Headphones |
Power | |
