Perfect for small rooms or when space is limited, the 22DL704 delivers Full High Definition image quality with the added convenience of a built-in DVD player. Using LED technology, you'll enjoy amazing color, brightness and clarity, all in a super-thin design.
Along with the reassurance of Toshiba quality and great affordability, the DL702 series also includes built-in Freeview digital TV for access to up to 50 digital TV channels and 24 radio stations without subscription, plus video, photo and audio playback via USB. Multiple HDMI inputs and PC input make it easy to connect to other devices in your home.
Product Description | Toshiba 22DL704B REGZA DL Series - 22" LED-backlit LCD TV - Full HD - for hotel / hospitality | Product Type | LED-backlit LCD TV with built-in DVD player | Diagonal Class | 22" | Commercial Use | Hotel / hospitality | Resolution | 1920 x 1080 | Display Format | 1080p | Video Interface | Component, composite, HDMI, SCART | HDMI Ports Qty | 2 ports | PC Interface | VGA (HD-15) | HDCP Compatible | Yes | LCD Backlight Technology | LED backlight | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-T | Analogue TV Tuner | PAL, SECAM | Settings Cloning Capability | Yes | Sound Output Mode | Stereo | Speaker System | 2 speakers | Stereo Reception System | NICAM | DVD | DVD player - built-in | USB | Yes | Energy Class | Class A | Power Consumption Operational | 45 Watt | Power Consumption (On mode) | 21 W | Energy Consumption per Year | 31 kWh | Dimensions (WxDxH) - with stand | 53 cm x 15.2 cm x 37.6 cm | Weight | 4.6 kg |
General | |
Product Type | LED-backlit LCD TV |
Combined With | Built-in DVD player |
Series | REGZA DL Series |
TV Tuner Presence | Yes |
Modes | Game mode, hotel mode |
Dimensions | With stand |
Width | 53 cm |
Depth | 15.2 cm |
Height | 37.6 cm |
Weight | 4.6 kg |
Display | |
Dynamic Contrast Ratio | 3000000:1 |
Brightness | 300 cd/m² |
Widescreen Modes | Conventional 4:3 |
Viewing Angle | 178 degrees |
Viewing Angle (Vertical) | 178 degrees |
Response Time | 9 ms |
Max V-Sync Rate | 50 Hz |
Comb Filter | 3D digital |
Colour Temperature Control | Yes |
Features | Audio Description (AD), Automatic Format Detection (AFD), 3D Color Management, Digital Noise Reduction (DNR), MPEG Noise Reduction, Automatic Channel Install (ACI) |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
DVD | |
Type | DVD player - built-in |
Media Type | DVD-R, DVD-RW, DVD, CD |
Features | JPEG photo playback, MP3 playback |
TV Tuner | |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | FREEVIEW |
Digital Channel Qty | 800 channels |
Video Features | |
Analogue Video Input Signals | NTSC, PAL, SECAM |
Teletext | Yes |
Teletext Memory | 1000 pages |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 1 |
Radio | |
Preset Station Qty | 24 channels |
Audio System | |
Output Power / Total | 5 Watt |
Speakers | 2 x main channel speaker - 2.5 Watt |
Connections | |
Connector Type | 2 x HDMI , VGA / component video input , Composite video input , SCART , USB , Headphones , SPDIF output |
Power | |
Power Device | Power supply |
Power Consumption Stand by / Sleep | 0.5 Watt |
