Toshiba 1TB StorE Basics 2.5 inch USB 3.0 External Hard Drive Black
Quickly transfer files with SuperSpeed USB 3.0 and store up to 1TB of data on STOR. E BASICS external drives. Easy to use and backward compatible with USB 2.0, STOR. E BASICS external drives are ready to use with no software installation required.
Key Features
The Toshiba STOR.E Basics 2.5 Inch 1TB external hard drive makes super speed storage simple. Receive high speed storage via the USB 3.0 port, allowing you to store your data with super speed. It's backwards compatible with USB 2.0 and is easy to use for everybody. An easy plug and play operation makes it ready to use with Microsoft Windows with no software installation required. Enjoy high capacity storage of up to 1TB in a conveniently .compact casing
Box Contents
System requirements
Product Description | Toshiba StorE BASICS - hard drive - 1 TB - USB 3.0 | Type | Hard drive - external (portable) | Capacity | 1 TB | Form Factor | 2.5" | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Features | Ramp Load | Power Source | USB bus | Enclosure Colour | Matte black | Dimensions (WxDxH) | 7.9 cm x 11.9 cm x 1.7 cm | Weight | 180 g | Designed For | Dynabook Toshiba Portégé R830, R930, Z830, Z930; Toshiba Satellite Pro C850, L830, L850, L870; Toshiba Tecra A11, R840, R940, R950; Toshiba LX830; NB510; NB520; Qosmio F750, X770, X870; Satellite C660, C670, C850, C850D, C855, C855D, C870, C870D, C875, C875D, L730, L735, L750, L750D, L755, L755D, L775, L775D, L830, L850, L850D, L855, L855D, L870, L875, L875D, L955, L955D, P750, P770, P845T, P850, P855, P870, P875, R830, R930, S70, U840, U840W, U920t, U940, Z830, Z930 |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 1 TB |
Width | 7.9 cm |
Depth | 11.9 cm |
Height | 1.7 cm |
Weight | 180 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 - 10 pin Micro-USB Type B |
Compatible Bay | 2.5" |
Power | |
Software & System Requirements | |
OS Required | Microsoft Windows 7 |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external |
Compliant Standards | Plug and Play |
Compatibility Information | |
Designed For | Dynabook Toshiba Portégé R930-14X, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV, Z930-13L, Z930-13M, Z930-147, Z930-14D, Z930-153 , Dynabook Toshiba Satellite Pro C850-19G, C850-1CV, C850-1D4, C850-1DC, C850-1DE, C850-1FJ, C850-1FR, C850-1GR, C850-1H8, C850-1HD, C850-1HE, C850-1K1, C850-1K2, C850-1K3, C850-1K4, C850-1LV, C850-1M7, L830-13E, L830-13R, L830-14F, L830-15W, L850-1KM, L850-1L4, L850-1MH, L850-1MJ, L850-1P7, L850-1P8, L850-1UJ, L850-1UK, L870-16Z, L870-171, L870-172, L870-179, L870-17X, L870-18G, L870-18L, L870-18R , Dynabook Toshiba Tecra R940-1GQ, R940-1JF, R940-1JG, R940-1JH, R940-1L0, R940-1L1, R950-176, R950-1EJ, R950-1EK, R950-1EL, R950-1EM, R950-1EN, R950-1JH, R950-1JJ , Toshiba LX830-11G , Toshiba Qosmio X870-13U, X870-13Z, X870-140, X870-141, X870-142, X870-149, X870-15K , Toshiba Satellite C850-1DV, C850-1DW, C850-1GL, C850-1LH, C850-1LW, C850-1M8, C850-1MC, C850D-11F, C850D-121, C850D-12L, C850D-12V, C855-1TH, C855-1TJ, C855-1U8, C855-1VU, C855-1W9, C855-1XH, C855-253, C855-25L, C855-28U, C855-29L, C855-29M, C855-29N, C855-2EE, C855-2EF, C855-2ET, C855-2EU, C855-2EZ, C855-2F0, C855-2F1, C855-2F2, C855-2F3, C855-2F7, C855-2F8, C855-2F9, C855-2FC, C855D-12P, C855D-13J, C855D-149, C855D-14C, C855D-15W, C855D-15Z, C870-17L, C870-17T, C870-17U, C870-1F3, C870-1GF, C870-1H2, C870-1HE, C870D-11X, C875-114, C875-150, C875D-10E, L830-13J, L830-14G, L830-15G, L830-15H, L830-15J, L830-160, L830-164, L850-1K8, L850-1V0, L850D-12P, L855-14K, L855-14W, L855-15L, L855-15U, L855-179, L855-17Q, L855-17R, L855D-10G, L855D-10H, L870-18Q, L870-18V, L875-12V, L955-108, L955-10F, L955-10J, L955D-104, L955D-107, L955D-10F, P845t-103, P845t-104, P845T-108, P845t-10G, P845t-10J, P850-31W, P850-31X, P850-31Z, P850-320, P850-32D, P850-32M, P850-32Z, P855-33X, P855-34P, P870-31G, P870-320, R930-1CV, S70-B-10F, U920t-10F, U920t-117, U920t-11C, U940-101, U940-104, U940-11N, Z930-13C |
The following resources are available for the Toshiba 1TB Stor.E Basics USB 3.0 2.5" Portable Hard Drive Black
