Toshiba 1TB StorE ALU 2S 2.5 Inch USB 3.0 External Hard Drive - Silver
Store your data with an amazing transfer rate. In its silver aluminum casing this hard drive not only is a beauty but gives you more safety for your data.
Incl. pre-loaded Nero® BackItUp 12 Essentials
In The Box
Product Description | Toshiba StorE Alu 2S - hard drive - 1 TB - USB 3.0 | Type | Hard drive - external (portable) | Capacity | 1 TB | Form Factor | 2.5" | Interface | USB 3.0 | Features | Bus Powered by USB | Enclosure Colour | Silver | Dimensions (WxDxH) | 7.7 cm x 12 cm x 14.5 cm | Weight | 175 g | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 2-year warranty | Designed For | Dynabook Toshiba Portégé R830, R930, Z830, Z930; Toshiba Satellite Pro C850, L830, L850, L870; Toshiba Tecra A11, R840, R940, R950; Toshiba LX830; NB510; NB520; Qosmio F750, X770, X870; Satellite C660, C670, C850, C850D, C855, C855D, C870, C870D, C875, C875D, L730, L735, L750, L750D, L755, L755D, L775, L775D, L830, L850, L850D, L855, L855D, L870, L875, L875D, L955, L955D, P750, P770, P775, P845T, P850, P855, P870, P875, R830, R930, S70, U840, U840W, U920t, U940, Z830, Z930 |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 1 TB |
Width | 7.7 cm |
Depth | 12 cm |
Height | 14.5 cm |
Weight | 175 g |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 |
Compatible Bay | 2.5" |
Software & System Requirements | |
Software Included | Toshiba Market Place |
OS Required | Microsoft Windows Vista / XP / 7 |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | SASO, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
Designed For | Dynabook Toshiba Portégé R930-14X, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV, Z930-13L, Z930-13M, Z930-147, Z930-14D, Z930-153 , Dynabook Toshiba Satellite Pro C850-19G, C850-1C3, C850-1CV, C850-1CW, C850-1D4, C850-1DC, C850-1DE, C850-1EQ, C850-1ER, C850-1FJ, C850-1FN, C850-1FR, C850-1GR, C850-1H8, C850-1HD, C850-1HE, C850-1K1, C850-1K2, C850-1K3, C850-1K4, C850-1LV, C850-1M7, L830-13E, L830-13R, L830-14F, L830-15W, L850-1KM, L850-1L4, L850-1MH, L850-1MJ, L850-1P7, L850-1P8, L850-1UJ, L850-1UK, L870-16Z, L870-171, L870-172, L870-179, L870-17X, L870-18G, L870-18L, L870-18R , Dynabook Toshiba Tecra R940-1GQ, R940-1JF, R940-1JG, R940-1JH, R940-1L0, R940-1L1, R950-176, R950-1EJ, R950-1EK, R950-1EL, R950-1EM, R950-1EN, R950-1JH, R950-1JJ , Toshiba LX830-11G , Toshiba Qosmio X870-13U, X870-149 , Toshiba Satellite C850-1DV, C850-1DW, C850-1GL, C850-1LH, C850-1LW, C850-1M8, C850-1MC, C850D-11F, C850D-121, C850D-12L, C850D-12V, C855-1TH, C855-1TJ, C855-1U8, C855-1VU, C855-1W9, C855-1XH, C855-253, C855-25L, C855-28U, C855-29L, C855-29M, C855-29N, C855-2EE, C855-2EF, C855-2ET, C855-2EU, C855-2EZ, C855-2F0, C855-2F1, C855-2F2, C855-2F3, C855-2F7, C855-2F8, C855-2F9, C855-2FC, C855D-12P, C855D-13J, C855D-149, C855D-14C, C855D-15W, C855D-15Z, C870-17L, C870-17T, C870-17U, C870-1F3, C870-1GF, C870-1H2, C870-1HE, C870D-11X, C875-114, C875-150, C875D-10E, L830-13J, L830-14G, L830-15G, L830-15H, L830-15J, L830-160, L830-164, L850-1K8, L850-1V0, L850D-12P, L855-14K, L855-14W, L855-15L, L855-15U, L855-179, L855-17Q, L855-17R, L855D-10G, L855D-10H, L870-18Q, L870-18V, L875-12V, L955-108, L955-10F, L955-10J, L955D-104, L955D-107, L955D-10F, P845t-103, P845t-104, P845T-108, P845t-10G, P845t-10J, P850-31W, P850-31X, P850-31Z, P850-320, P850-32D, P850-32M, P850-32Z, P855-33X, P855-34P, P870-31G, P870-320, R930-1CV, S70-B-10F, U920t-10F, U920t-117, U920t-11C, U940-101, U940-104, U940-11N, Z930-13C |
