TomTom GO is the smart, easy-to-use, portable navigation solution. Switch it on and GO. The crystal-clear widescreen display, 3D graphics and voice instruction help you ?nd your way to any address in the United States and Canada. A few taps of the screen get you going. Pick a destination, choose the type of route, and it guides you door-to-door. The built-in Bluetooth connection lets you easily make or receive calls hands-free. And with TomTom PLUS the GO can re-route you around traffic jams and alert you to bad weather. Easily control your iPod directly from your TomTom GO. Just tap the GO's widescreen to see, select and play your favorite iPod tunes. The home dock lets you connect to your PC for itinerary planning and downloading maps, voices, and more. The portable, widescreen TomTom GO is the smart and easy choice for every car, every trip, everyday.
Product Description | TomTom GO 510 - GPS navigator | Product Type | GPS navigator | Display | 5" colour - 480 x 272 pixels - widescreen | Input | Touch sensitive screen | Recommended Use | Automotive | Preloaded Maps | Worldwide | Interface | USB, Bluetooth | Internal Memory | 8 GB | Traffic | TomTom Traffic | Speed Camera Warning | Yes | Voice | Navigation instructions, street name announcement, voice command recognition | Spoken Navigation | Danish, Hungarian, Czech, Irish, Latin, Croatian, Slovenian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Dutch, Greek, Turkish, Arabic, Bulgarian, Lithuanian, Serbian, Catalan, Afrikaans, UK English, Belgian, US English | Included Software | Lane Assistant | Card Reader | microSD | Included Accessories | Magnetic mount, USB car charger, USB cable | Dimensions (WxDxH) | 14.45 cm x 2.22 cm x 9.05 cm | Weight | 235 g |
General | |
Aerial | Built-in |
Features | TomTom QuickGPSfix, Advanced Lane Guidance, parking assistance, lifetime map updates, lifetime traffic updates, Tap & Go, Speak & Go, TomTom MyDrive, Point Of Interest (POI) |
Display | |
Type | TFT - colour - touch sensitive screen |
Diagonal Size | 5" - widescreen |
Display Resolution | 480 x 272 pixels |
Menu Language | Danish, Hungarian, Czech, Latin, Croatian, Slovenian, Slovak, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Spanish, Dutch, Greek, Turkish, Bulgarian, Latvian, Lithuanian, Estonian, Catalan, Afrikaans, UK English, US English |
Connections | |
Interfaces | USB , Bluetooth |
Miscellaneous | |
Dimensions & Weight | |
Width | 14.45 cm |
Depth | 2.22 cm |
Height | 9.05 cm |
Weight | 235 g |
