This Cockpit set (folding and wireless) features integrated high-precision wheel and pedals for PlayStation 3 and PC.
WHEEL: exact replica of the Ferrari F430 wheel (7/10 size)
- Ultra-precise wheel with new H.E.A.R.T HallEffect AccuRate Technology™ magnetic sensor technology, featuring 12-bit precision (4096 values on the wheel's rotation).
- Sequential Up & Down gearshift levers crafted of metal, for Ferrari GT-style driving.
- XXL wheel: 28cm in diameter!
- Genuine "Manettino®" dial with 5 backlit positions, to configure your wheel directly in the game (driving sensitivity, programming system, etc.).
- Rubber-textured grip, for optimal comfort.
- 100% programmable, with internal memory.
- Detachable wheel: cockpit takes up minimum space when stored.
- Compatible with 100% of PlayStation® 3 games and PC USB games (Windows® 7/Vista/XP).
PEDAL SET: 2 metal pedals integrated directly into the cockpit (for total stability)
- Metal pedals with long range of travel, inspired by the shape of the pedals on the Ferrari 430 Scuderia.
- Brake pedal with magnetic resistance for enhanced realism.
COCKPIT: streamlined with adjustable metal structure - folding and transportable, for easy storage
- 2.4GHz wireless system: 10m+ range with no latency.
- 50 hours of battery life with 4 AA LR6 batteries (not included).
- Wide, weighted base (10.5kg in total) for optimal stability.
- Adjustable, rigid metal structure: an infinite number of possible positions according to the user's size (adult/child) and seating type (sofa/chair).
- Foldable structure with carrying handle for easy storage.
- Position locking system: ultra-efficient and easy to use.
- Streamlined, with the metallic colors of the Ferrari 430 Scuderia "musetto".
Product Description | Thrustmaster Ferrari Wireless GT Cockpit 430 - Scuderia Edition - wheel and pedals set - wireless | Product Type | Wheel and pedals set | Connectivity Technology | Wireless | Pointing Device / Manipulator | Wheel and pedals set | Features | Built-in flash memory, adjustable size, rubber coating, foldable, H.E.A.R.T HallEffect AccuRate Technology, carrying handle | Manufacturer Warranty | 2-year warranty |
General | |
Max Operating Distance | Up to 10 m |
Interface | USB |
Connectivity | |
Interfaces | 1 x USB |
System Requirements | |
OS Required | Microsoft Windows Vista / XP / 7 |
Miscellaneous | |
Required Battery | AA type |
Weight | 10.5 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
