The Techair UltraBook Portrait case is specifically designed to carry and protect Ultrabooks and other slim 12"-13.3" laptops. When on the move your Ultrabook is safely secured in the fur lined laptop compartment providing soft abrasion free protection. An additional pocket provides space for accessories and power supply. The luxury webbing shoulder strap and durable material all add up to making a great light weight product that will compliment your UltraBook.
Product Features
- Number of compartments: 2
- Colour: Black
- Laptop compartment dimensions: 33 x 23 x 2 cm
- External dimensions: 24 x 35 x 4 cm
- Weight: 0.31 Kgs
With
900 x 1200 Polyester; life time warranty; UltraBook portrait case; 2 compartments, faux fur lining in laptop compartment; 1 pocket; cable friendly; document friendly; space for pens, CDs and business cards; adjustable and detachable shoulder strap, hand luggage compatible, made from showerproof material.
Product Description | techair 12"-13.3" Portrait Laptop Bag - notebook carrying case | Product Type | Notebook carrying case | Colour | Black | Product Material | Polyester | Dimensions (WxDxH) | 24 cm x 4 cm x 35 cm | Weight | 310 g | Notebook Compatibility | 13.3" | Notebook Supported Sizes | 12" - 13.3" / 30.5 cm - 33.8 cm | Features | Removable shoulder strap, shower proof, cabin luggage, faux fur inner lining | Carrying Strap | Adjustable shoulder strap | Manufacturer Warranty | Limited lifetime warranty |
General | |
Width | 24 cm |
Depth | 4 cm |
Height | 35 cm |
Weight | 310 g |
Notebook Compatibility Dimensions | 33 cm x 23 cm x 2 cm |
Additional Compartments | Cable, documents, pens, CD/DVD, business cards |
Closure Type | Zipper |
Lining Material | Faux fur |
Compartments Quantity | 2 |
Colour | Black |
Manufacturer Warranty | |
Service & Support | Limited warranty: - lifetime |
