Meet the ambitious DS916+ designed to satisfy professional NAS users' needs. With a powerful quad-core CPU, AES-NI hardware encryption engine, scalability up to nine drives, and 2GB or 8GB memory options, DS916+ brings better support for multitasking, and increases business dynamics.
Product Description | Synology Disk Station DS916+ - NAS server - 32 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 32 TB | Installed Devices / Modules Qty | 4 (installed) / 4 (max) | Dimensions (WxDxH) | 20.3 cm x 23.32 cm x 16.5 cm | Weight | ) | Processor | 1 x Intel Pentium N3710 1.6 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 4 x 8 TB | Networking | 10Mb LAN, 100Mb LAN, GigE | RAM | 2 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | Manufacturer Warranty | 3-year warranty |
General | |
Width | 20.3 cm |
Depth | 23.32 cm |
Height | 16.5 cm |
Weight | ) |
Processor / Memory | |
Processors Installed | 1 x Intel Pentium N3710 1.6 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 2 GB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s / eSATA |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD |
Capacity | 4 x 8 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | iSCSI |
Remote Management Protocol | HTTPS |
Network Services Compatibility | Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV) |
Features | LDAP support, Access Control List (ACL) support, Google Drive support |
Encryption Algorithm | AES, SSL, TLS, 256-bit AES |
Compliant Standards | DLNA CERTIFIED |
Security DVR | |
Compression Format | MPEG-2, H.264 |
Image Resolution | 1280x720, 1920x1080, 2048x1536, 2591x1944, 4096x2160 |
Frame Rate | 30 fps (playback) |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 3 x USB 3.0 , 2 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, RoHS, BSMI Class B |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 100 Watt |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
Sound Emission | 19.4 dBA |
