ITEM | QTY | PRICE |
Apple iPhone 14 128GB (PRODUCT)RED
1 | £599.00 |
Lenovo IdeaPad Slim 3 Chrome Core i3...
4 | £1,519.96 |
StarTech.com VESA Mount Adapter for T...
4 | £119.76 |
DS716+II is the perfect combination of scalability, performance, and versatility. It can deliver high-speed encrypted data transfer, 4K transcoding, and is running Btrfs, an enhanced file system.
Product Description | Synology Disk Station DS716+II - NAS server - 2 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 2 TB | Installed Devices / Modules Qty | 2 (installed) / 2 (max) | Dimensions (WxDxH) | 10.35 cm x 23.2 cm x 15.7 cm | Weight | ) | Processor | 1 x Intel Celeron N3160 1.6 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, JBOD | Hard Drive | 2 x 1 TB | Networking | 10Mb LAN, 100Mb LAN, GigE | RAM | 2 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | Manufacturer Warranty | 3-year warranty |
General | |
Width | 10.35 cm |
Depth | 23.2 cm |
Height | 15.7 cm |
Weight | ) |
Processor / Memory | |
Processors Installed | 1 x Intel Celeron N3160 1.6 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 2 GB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s / eSATA |
RAID Level | RAID 0, RAID 1, JBOD |
Hard Drive | |
Type | HDD - hot-swap |
Capacity | 2 x 1 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | PPTP, iSCSI, SMTP, FTP, POP3, IMAP |
Remote Management Protocol | SNMP, Telnet, IPP, HTTP, HTTPS, SSH |
Network Services Compatibility | Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, LDAP support, wake on LAN (WOL), print server, antivirus analysis, web server, backup server, download client, event log, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, FTP server, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, 4K resolution support, cloud backup, VPN Server, Wi-Fi USB dongle support |
Encryption Algorithm | SSL, TLS, 256-bit AES |
Compliant Standards | DLNA CERTIFIED, UPnP |
Security DVR | |
Compression Format | MJPEG, MPEG-2, H.264 |
Image Resolution | 1920x1080, 2048x1536, 1280x800, 2591x1944, 4096x2160 |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 3 x USB 3.0 , 2 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan, AirPrint, Google Cloud Print |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
Sound Emission | 18 dBA |
