Synology DiskStation DS416play is a 4-bay NAS server with incredible fun. The massive storage capacity allows you to store your entire multimedia library and turns it into a centralized multimedia center. Powered by a hardware transcoding engine, DS416play delivers real-time transcoding of 4K Ultra HD to various kinds of devices you have, giving you a smooth and high quality streaming experience.
Product Description | Synology Disk Station DS416Play - NAS server - 16 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 16 TB | Installed Devices / Modules Qty | 4 (installed) / 4 (max) | Dimensions (WxDxH) | 20.3 cm x 23.32 cm x 16.5 cm | Weight | 2.04 kg () | Processor | 1 x Intel Celeron N3060 1.6 GHz (Dual-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 4 x 4 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 25 | RAM | 1 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | System Requirements | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later | Manufacturer Warranty | 3-year warranty |
General | |
Width | 20.3 cm |
Depth | 23.32 cm |
Height | 16.5 cm |
Processor / Memory | |
Processors Installed | 1 x Intel Celeron N3060 1.6 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 1 GB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD - hot-swap - 3.5" |
Capacity | 4 x 4 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | PPTP, L2TP, SMTP, POP3, IMAP |
Remote Management Protocol | SNMP, Telnet, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, reset button, bandwidth control, surveillance station, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support |
Compliant Standards | DLNA CERTIFIED, UPnP |
Security DVR | |
Compression Format | MPEG-2 |
Frame Rate | 30 fps (playback) |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 3 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation |
Security Slot Type | Kensington security slot |
Compliant Standards | AES |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
