ITEM | QTY | PRICE |
HP 304 Black Original Ink Cartridge
4 | £50.40 |
StarTech.com USB-C Multiport Adapter...
4 | £136.72 |
Techair 14-15.6" Black Classic B...
3 | £71.13 |
Synology DiskStation DS416j is a 4-bay NAS server specifically designed for home and personal users to effectively manage, protect and share data. You can enjoy effortless data sharing, multimedia streaming and cloud synchronization features while keeping data safe and secure.
Product Description | Synology Disk Station DS416j - NAS server - 40 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 40 TB | Installed Devices / Modules Qty | 4 (installed) / 4 (max) | Dimensions (WxDxH) | 16.8 cm x 23 cm x 18.4 cm | Weight | 2.21 kg () | Processor | 1 x Marvell 88F6828 1.3 GHz (Dual-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 4 x 10 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, 1GbE | IP Cameras Supported | 25 | RAM | 512 MB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | System Requirements | Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later | Manufacturer Warranty | 2-year warranty |
General | |
Width | 16.8 cm |
Depth | 23 cm |
Height | 18.4 cm |
Processor / Memory | |
Processors Installed | 1 x Marvell 88F6828 1.3 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 512 MB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD - hot-swap - 3.5" |
Capacity | 4 x 10 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE |
Network / Transport Protocol | PPTP, L2TP, SMTP, POP3, IMAP |
Remote Management Protocol | SNMP, Telnet, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, bandwidth control, surveillance station, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support |
Compliant Standards | DLNA CERTIFIED, UPnP |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 1 x USB 2.0 - Type A , 1 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation |
Security Slot Type | Kensington security slot |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
