Synology DiskStation DS416 is a high-performance and feature-rich 4-bay NAS specifically designed for small businesses and home users to effectively manage, protect and share data. Equipped with comprehensive office applications, DS416 raises working efficiency while securing data with full backup solutions.
Product Description | Synology Disk Station DS416 - NAS server - 12 TB - TAA Compliant | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 12 TB | Max Supported Capacity | 32 TB | Installed Devices / Modules Qty | 4 (installed) / 4 (max) | Dimensions (WxDxH) | 20.3 cm x 23.32 cm x 16.5 cm | Weight | ) | Processor | 1 x Cortex-A15 1.4 GHz (Dual-Core) | Storage Controller | RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 4 x 3 TB | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 25 | RAM | 1 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | System Requirements | Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later | TAA Compliant | Yes | Manufacturer Warranty | 2-year warranty |
General | |
Width | 20.3 cm |
Depth | 23.32 cm |
Height | 16.5 cm |
Weight | ) |
Processor / Memory | |
Processors Installed | 1 x Cortex-A15 1.4 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 1 GB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD |
Capacity | 4 x 3 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | PPTP, L2TP, SMTP, POP3, IMAP |
Remote Management Protocol | SNMP, Telnet, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, bandwidth control, surveillance station, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support |
Compliant Standards | DLNA CERTIFIED, UPnP |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 3 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation |
Security Slot Type | Kensington security slot |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
