Synology DiskStation DS216se is a budget-friendly two-bay NAS device with the capability to host, share and protect data. Sharing the variety of packages in DSM Package Center, DS216se helps beginners explore the infinite possibilities of Synology NAS.
Product Description | Synology Disk Station DS216se - NAS server - 4 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 4 TB | Max Supported Capacity | 16 TB | Installed Devices / Modules Qty | 2 (installed) / 2 (max) | Dimensions (WxDxH) | 10 cm x 22.25 cm x 16.5 cm | Weight | ) | Processor | 1 x Marvell ARMADA 370 800 MHz | Storage Controller | RAID SATA 6Gb/s RAID 0, 1, JBOD | Hard Drive | 2 x 2 TB | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 5 | RAM | 256 MB | Power | AC 120/230 V (50/60 Hz) | System Requirements | Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later | Manufacturer Warranty | 2-year warranty |
General | |
Width | 10 cm |
Depth | 22.25 cm |
Height | 16.5 cm |
Weight | ) |
Processor / Memory | |
Processors Installed | 1 x Marvell ARMADA 370 800 MHz |
Max Supported Qty | 1 |
RAM | 256 MB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, JBOD |
Hard Drive | |
Type | HDD |
Capacity | 2 x 2 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | PPTP, L2TP, SMTP, POP3, IMAP |
Remote Management Protocol | SNMP, Telnet, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, wake on LAN (WOL), download client, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, bandwidth control, Energy Efficient Ethernet, VPN Server, automated backup scheduling, Wi-Fi USB dongle support |
Compliant Standards | DLNA CERTIFIED, UPnP |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 0 (free) x internal - 2.5" / 3.5" |
Interfaces | 2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation |
Security Slot Type | Kensington security slot |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12.x, Android 4.0 or later, Apple iOS 7 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
