Fulfill your needs for safe data storage and ultra high definition video sharing with Synology DiskStation DS216+II. Powered by a dual-core CPU, DS216+II comes with hardware-accelerated data encryption and real-time transcoding of 4K Ultra HD source content.
Product Description | Synology Disk Station DS216+II - NAS server - 2 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 2 TB | Installed Devices / Modules Qty | 2 (installed) / 2 (max) | Dimensions (WxDxH) | 10.8 cm x 23.32 cm x 16.5 cm | Weight | 1.25 kg () | Processor | 1 x Intel Celeron N3060 1.6 GHz (Dual-Core) | Storage Controller | RAID SATA 6Gb/s / eSATA 6Gb/s RAID RAID 0, 1, JBOD | Hard Drive | 2 x 1 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 25 | RAM | 1 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | System Requirements | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later | Manufacturer Warranty | 2-year warranty |
General | |
Width | 10.8 cm |
Depth | 23.32 cm |
Height | 16.5 cm |
Processor / Memory | |
Processors Installed | 1 x Intel Celeron N3060 1.6 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 1 GB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s / eSATA 6Gb/s |
RAID Level | RAID 0, RAID 1, JBOD |
Hard Drive | |
Type | HDD - hot-swap - 3.5" |
Capacity | 2 x 1 TB |
Interface Type | SATA 6Gb/s |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | PPTP, L2TP, FTP, SMB, NFS |
Remote Management Protocol | SNMP, Telnet, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, LDAP support, wake on LAN (WOL), Syslog support, DoS attack prevention, print server, web server, download client, Access Control List (ACL) support, iTunes server, e-mail server, reset button, DNS server, VPN Server, Wi-Fi USB dongle support |
Encryption Algorithm | AES, SSL |
Compliant Standards | DLNA CERTIFIED |
Security DVR | |
Compression Format | MPEG-2, H.264 |
Image Resolution | 4096 x 2160 |
Frame Rate | 30 fps (playback) |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 0 (free) x internal - 2.5" / 3.5" |
Interfaces | 1 x USB 3.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x eSATA 6Gb/s |
Miscellaneous | |
Cables Included | 1 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption, 24x7 continuous operation, fan speed controller |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, RoHS, BSMI Class B, TLS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 60 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
