Synology DiskStation DS1517+ features a quad-core processor with AES-NI hardware encryption engine, providing outstanding performance even with encryption. Supercharge your storage with the optional M.2 SSD adapter card for dual SSD cache drives. DS1517+ is the ideal storage solution for centralizing data backups, protecting critical assets, and sharing files across different platforms. Synology DS1517+ is backed with Synology’s 3-year limited warranty.
Product Description | Synology Disk Station DS1517+ - NAS server | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Max Supported Capacity | 50 TB | Installed Devices / Modules Qty | 0 (installed) / 5 (max) | Dimensions (WxDxH) | 25 cm x 24.3 cm x 16.6 cm | Weight | 4.46 kg () | Processor | 1 x Intel Atom C2538 2.4 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Networking | 10Mb LAN, 100Mb LAN, 1GbE | IP Cameras Supported | 40 | RAM | 8 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | System Requirements | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later | Manufacturer Warranty | 3-year warranty |
General | |
Total Storage Capacity | 0 GB |
Width | 25 cm |
Depth | 24.3 cm |
Height | 16.6 cm |
Processor / Memory | |
Processors Installed | 1 x Intel Atom C2538 2.4 GHz |
Number of Cores | Quad-Core |
RAM | 8 GB (installed) / 16 GB (supported) - DDR3 |
Features | Dual channel memory architecture |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, iSCSI, FTP |
Remote Management Protocol | SNMP, Telnet, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, High Availability, video server, web server, backup server, file sharing, anti-malware protection, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, surveillance station, PXE support, Apple Time Machine compatible, cloud backup, VPN Server, SFTP client, anti-virus protection, DLNA support |
Encryption Algorithm | SSL, TLS |
Compliant Standards | DLNA CERTIFIED |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 1 x PCI Express x8 |
Interfaces | 4 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, RoHS, BSMI Class B |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 42.1 Watt |
Power Consumption Stand by | 23.1 Watt |
Power Provided | 200 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, Synology Assistant |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
