The Btrfs file system introduces the most advanced storage technologies to prevent data corruption and reduce maintenance overhead with optimized snapshots. It ensures high-level data integrity, while taking advantage of flexible, efficient data protection and recovery tools.
Equipped with dual-channel memory and a PCIe slot, DS1517+ supports installing the dual M.2 SSD adapter card, M2D17, or the 10GbE NIC, for high-IOPS system cache and ultra-fast data transmission respectively.
Product Description | Synology Disk Station DS1517+ - NAS server - 30 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 30 TB | Max Supported Capacity | 50 TB | Installed Devices / Modules Qty | 5 (installed) / 5 (max) | Dimensions (WxDxH) | 25 cm x 24.3 cm x 16.6 cm | Weight | ) | Processor | 1 x Intel Atom C2538 2.4 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 5 x 6 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, 1GbE | IP Cameras Supported | 40 | RAM | 8 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | System Requirements | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later | Manufacturer Warranty | 3-year warranty |
General | |
Width | 25 cm |
Depth | 24.3 cm |
Height | 16.6 cm |
Weight | ) |
Processor / Memory | |
Processors Installed | 1 x Intel Atom C2538 2.4 GHz |
Number of Cores | Quad-Core |
RAM | 8 GB (installed) / 16 GB (supported) - DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD |
Capacity | 5 x 6 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, iSCSI, FTP |
Remote Management Protocol | SNMP, Telnet, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, High Availability, video server, web server, backup server, file sharing, anti-malware protection, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, surveillance station, PXE support, Apple Time Machine compatible, cloud backup, VPN Server, SFTP client, anti-virus protection, DLNA support |
Encryption Algorithm | SSL, TLS, AES-NI |
Compliant Standards | DLNA CERTIFIED |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 1 x PCI Express 2.0 x8 |
Interfaces | 4 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, RoHS, BSMI Class B |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 42.1 Watt |
Power Consumption Stand by | 23.1 Watt |
Power Provided | 200 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, Synology Assistant |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.10 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
