Synology DiskStation DS1515+ features a quad core CPU with an AES-NI hardware encryption engine, providing outstanding performance and data encryption acceleration. With four built-in Gigabit LAN ports and scalability of up to 15 drives, Synology DS1515+ is the cost-effective storage solution for centralizing data backups, protecting critical assets and sharing files across different platforms.
Product Description | Synology Disk Station DS1515+ - NAS server - 10 TB - TAA Compliant | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 10 TB | Max Supported Capacity | 30 TB | Installed Devices / Modules Qty | 5 (installed) / 5 (max) | Dimensions (WxDxH) | 24.8 cm x 23.3 cm x 15.7 cm | Weight | 4.17 kg () | Processor | 1 x Intel Atom C2538 2.4 GHz (Quad-Core) | Storage Controller | RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare | Hard Drive | 5 x 2 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | IP Cameras Supported | 40 | RAM | 2 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Synology DiskStation Manager | System Requirements | Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later | TAA Compliant | Yes | Manufacturer Warranty | 3-year warranty |
General | |
Width | 24.8 cm |
Depth | 23.3 cm |
Height | 15.7 cm |
Processor / Memory | |
Processors Installed | 1 x Intel Atom C2538 2.4 GHz |
Number of Cores | Quad-Core |
RAM | 2 GB (installed) / 6 GB (supported) - DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 3Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare |
Hard Drive | |
Type | HDD - hot-swap - 3.5" |
Capacity | 5 x 2 TB |
Interface Type | SATA 6Gb/s |
Buffer Size | 64 MB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, iSCSI, SMTP, FTP, POP3, IMAP |
Remote Management Protocol | SNMP, Telnet, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV) |
Features | Firewall protection, LDAP support, Syslog support, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, Advanced Data Streaming (ADS), RADIUS support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, DNS server, DLNA Media Server, eMule client, VPN Server |
Compliant Standards | DLNA CERTIFIED, UPnP |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 4 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Wake on LAN, built-in 2 cooling fans, hardware encryption |
Compliant Standards | FCC Class B certified, RoHS, BSMI Class B |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 250 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, Synology Assistant |
OS Required | Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% |
