Includes 1 x WD 1TB Red Hard Drive
Synology DiskStation DS213 is a feature-rich 2-bay NAS server for workgroups and offices, specifically designed for users who need to share and protect data cost-effectively, while increasing productivity with comprehensive office applications.
Synology DS213 delivers an average 108.41 Mbps reading speed under RAID 1 configuration in a Windows environment, and 65.36 Mbps writing. DiskStation DS213 provides a reliable solution for data sharing with an easy to use interface, and comprehensive office applications, including a complete backup solution making it one of the best values in 2-bay NAS devices available today. Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS213 takes less time for data transfer for external hard drives and consumes less power. In addition, hot-swappable drives make it easier for maintenance and hard drive replacement.
Product Description | Synology Disk Station DS213 - NAS server - TAA Compliant | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Max Supported Capacity | 8 TB | Installed Devices / Modules Qty | 2 (max) | Dimensions (WxDxH) | 10.8 cm x 23.32 cm x 16.5 cm | Weight | 1.25 kg () | Localisation | Danish, Hungarian, Czech, Slovenian, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Russian, Spanish, Dutch, Turkish, Japanese, Korean | Processor | 1 x 2 GHz | Storage Controller | RAID SATA 3Gb/s RAID RAID 0, 1, JBOD | Card Reader | Yes | Networking | Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE | RAM | 512 MB | Power | AC 120/230 V (50/60 Hz) | System Requirements | Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later | TAA Compliant | Yes | Manufacturer Warranty | 2-year warranty |
General | |
Total Storage Capacity | 0 GB |
Width | 10.8 cm |
Depth | 23.32 cm |
Height | 16.5 cm |
Processor / Memory | |
Processors Installed | 1 x 2 GHz |
Max Supported Qty | 1 |
RAM | 512 MB DDR3 |
Storage Controller | |
Type | RAID - internal |
Interface Type | SATA 3Gb/s |
Data Transfer Rate | 300 MBps |
Max Storage Devices Qty | 2 |
RAID Level | RAID 0, RAID 1, JBOD |
Hard Drive | |
Type | HDD - hot-swap |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | SD Memory Card |
Networking | |
Type | Network adapter - integrated |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | PPTP, PPPoE, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, DDNS |
Remote Management Protocol | SNMP, Telnet, IPP, HTTP, HTTPS, SSH |
Network Services Compatibility | DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV) |
Features | Firewall protection, hardware encryption, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, print server, IPv6 support, MySQL server, web server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, WebDAV server, VPN Server |
Encryption Algorithm | SSL, TLS |
Compliant Standards | DLNA CERTIFIED, UPnP |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 2 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 2 x USB 3.0 - Type A , 1 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Features | Built-in cooling fan, AirPrint, Google Cloud Print |
Compliant Standards | FCC Class B certified, RoHS, BSMI Class B |
Included Accessories | Mounting kit |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 18.48 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, Synology Assistant, Synology Data Replicator |
OS Required | Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Sound Emission | 19.9 dBA |
