This VGA over Cat 5 Video Extender is designed to extend VGA and RS 232 data signals over cost effective CAT5 (UTP) cable. Used in pairs, the VGA and RS 232 extender is ideal for home or commercial applications as a smart, fast and cost-effective solution. Now, you can broadcast video and control a projector or any other RS-232 devices from a remote location, making this video extender the perfect solution for touch screen or auto control equipment application.
Product Description | StarTech.com VGA Video Extender over Cat 5 with RS232 - monitor/serial extender | Device Type | Monitor/serial extender | Form Factor | External | Localisation | United Kingdom | Transmission Medium | CAT 5 | Max Transfer Distance | 300 m | Manufacturer Warranty | 2-year warranty |
General | |
Colour | Black |
Networking | |
Connectivity Technology | Wired |
Max Resolution | 1600 x 1200 @ 85 Hz |
Max Video Bandwidth | 150 MHz |
Expansion / Connectivity | |
Interfaces | 1 x VGA - HD-15 , 1 x RS-232 - DB-9 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
