Connect a DVI display for an entry-level extended desktop multi-monitor USB solution. The USB2DVIE2 USB DVI Multi Monitor External Video Adapter turns an available USB 2.0 port into an external video card DVI port - providing high quality dual-display or multi-monitor capability that can be used in a variety of laptop or desktop applications to increase your productivity.
The device also offers the option of running up to five additional displays simultaneously (using five USB2DVIE2 Multi Monitor External Video Cards). Each connected adapter can be used to further extend the desktop or mirror the image shown on the existing display - all without having to open the computer case to install an additional video card.
Product Description | StarTech.com USB DVI External Dual or Multi Monitor Video Adapter - external video adapter - 16 MB - black | Device Type | External video adapter | Bus Type | USB 2.0 | Memory | 16 MB | Max Resolution | 1680 x 1050 | Interfaces | DVI-I (Single-Link) | Dimensions (WxDxH) | 5.3 cm x 9.1 cm x 1.8 cm | Enclosure Colour | Black | Manufacturer Warranty | 2-year warranty | Designed For | P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6 |
General | |
Memory | |
Size | 16 MB |
Video Output | |
Colours Max Resolution (external) | 32-bit colour |
System Requirements | |
OS Required | Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits) |
Additional Requirements | SVGA monitor, USB 2.0 port |
System Requirements Details | Windows 2000/XP/Vista |
Miscellaneous | |
Cables Included | 1 x USB cable |
Software Included | Drivers & Utilities |
Compliant Standards | WHQL, FCC, RoHS |
Width | 5.3 cm |
Depth | 9.1 cm |
Height | 1.8 cm |
Weight | 108 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
