StarTech.com USB Multi-Media Card Reader
£23.77
34 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • USB 3.0 MULTI-CARD READER: USB 5Gbps Card Reader features 1x SD, 1x microSD, and 1x CompactFlash (CF) drive slot; USB-powered card reader allows for simultaneous read/write operations to all three drive slots using a single USB-A or USB-C port
  • MULTI-DEVICE CONNECTIVITY: 1ft (30cm) attached cable with a USB-C host connector and an integrated USB-A adapter enables connectivity to a variety of host devices; Compact and lightweight design for mobile users and business travelers
  • NO DRIVERS OR SOFTWARE: Supports any operating system including Windows, macOS, Linux, ChromeOS, Android, and iPadOS; Ideal for storing, editing, and transferring content in videography, photography, podcasting, and social media applications
  • WRITE/RE-WRITE PROTECTION: SD card slot supports the mechanical write protection switch, which helps prevent accidental or unauthorized deletion, modification, or overwriting of data; Use the same card on multiple hosts while ensuring data protection
  • WIDE COMPATIBILITY: Works with High-Capacity and Extended-Capacity SD Cards (i.e. SDHC, microSDHC, SDXC, and microSDXC); Compatible with miniSD when used with adapters (not included); Supports Secure Digital v3.0 UHS-I
  • Supported Formats: SDHC Memory Card, microSDHC, CompactFlash Card type II, SD 3.0 UHS-I + 4 more
  • Interface: USB 3.0/USB-C
Product codes
chevron icon
chevron icon
The USB 3.0 Multi-Media Card Reader allows for simultaneous read and write operations on SD, microSD, and CompactFlash cards using a single USB-C or USB-A port.
chevron icon
Product Description StarTech.com USB 3.0 Multi-Media Memory Card Reader, SD/microSD/CompactFlash Card Reader, Portable USB 5Gbps Card Adapter, External USB-C Card Reader with Attached USB-A Adapter - Works with Any Operating System (FCREADMICRO3V2) - card reader - USB 3.0/USB-C
Product Type Card reader - external
Supported Memory Cards CompactFlash Card type II, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC, SD 3.0 UHS-I
Host Interface USB 3.0/USB-C
Colour Grey
Features USB bus powered, Write Protect switch
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£23.77
