This USB to HDMI dual monitor adapter lets you add two independent HDMI displays to your computer using a single USB 3.0 port. One of the HDMI ports can output resolutions up to 4K, while the other can output resolutions up to 1920 x 1200.
Product Description | StarTech.com USB 3.0 to Dual HDMI Adapter, 1x 4K 30Hz & 1x 1080p, External Video & Graphics Card, USB Type-A to HDMI Dual Monitor Display Adapter Dongle, Supports Windows Only, Black - USB to Dual HDMI Adapter (USB32HD2) - adapter cable - HDMI / USB - TAA Compliant - 25 cm | Cable | Adapter cable - HDMI / USB | TAA Compliant | Yes | Max Output Resolution | 3840 x 2160 - 30 Hz | Length | 25 cm | Colour | Black | Connector | USB Type A - male (input) | Connector (Second End) | 2 x HDMI - female (output) | Compliant Standards | USB 3.0 | Features | 4K30Hz (3840 x 2160) support | Manufacturer Warranty | 2-year warranty | Designed For | P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50 |
General | |
Cable Type | Adapter cable 4K30Hz (3840 x 2160) support |
Interface Supported | HDMI / USB |
Length | 25 cm |
Features | 64 MB memory |
Colour | Black |
Adapters & Converters | |
Max Output Resolution | 3840 x 2160 |
Refresh Rate | 30 Hz |
OS Required | Microsoft Windows 7 / 8.1 / 10 (32/64 bits) |
Connectivity | |
Connector | 9 pin USB Type A - male (input) |
Connector (Second End) | 2 x 19 pin HDMI Type A - female (output) |
Miscellaneous | |
Compliant Standards | WHQL, FCC, RoHS |
Dimensions & Weight | |
Width | 6.6 cm |
Height | 1.5 cm |
Weight | 56 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.4 cm |
Shipping Depth | 20.7 cm |
Shipping Height | 3.8 cm |
Shipping Weight | 184 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
