Samsung TV Promotion: Save up to £250 across the range.
StarTech.com TV Wall Mount - Steel
£196.64
25 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • LARGE 70" TV WALL MOUNT: This heavy-duty TV wall mount supports VESA compatible displays (incl. curved TVs) up to 70 inch (99 lb/45 kg) w/ a durable full-motion steel frame and a powder-coated finish
  • WIDE RANGE OF MOTION: Articulating & adjustable TV wall mount offers +/-90° swivel, +2/-15° tilt & +/-5° LCD screen level adjustment without the use of additional tools to ensure display is level
  • EXTENDING ARMS: Arms extend from 2.4" (57mm) to 20.4" (517mm) from the wall; With the length of the arms, center of the television display has an overall lateral range (left to right) of 34.6" (880mm)
  • COMPATIBILITY: Universal TV wall mount supports LG, Samsung, Sony, Sharp, and others (screws/spacers incl) & VESA hole patterns 200x200, 400x200, 300x300, 400x400, 600x400, 400x300, 300x200.
  • TIDY AESTHETIC: The flat panel TV wall mounting bracket w/ integrated cable management & optional black snap-on covers keeps cables organized; ideal for customer-facing digital signage
  • Type: Mounting kit
Product codes
chevron icon
chevron icon
Free up space by mounting your flat-panel TV on a wall, with full-motion adjustment capability. Maximize space while creating an impressive display. With its dual-arm design, this heavy-duty TV wall mount securely supports large flat-screen TVs up to 70". The arms are easy to extend, to provide smooth, full-motion positioning for ideal viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, and frees up valuable space. The wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a large flat-panel TV or create digital signage. The TV wall mount supports most 32" to 70" (812.8 to 1778 mm) LED or LCD flat panel TVs weighing up to 99 lb. (45 kg).
The TV wall mount provides full-motion adjustment capability. The dual-arm extends up to 20.3" (517 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The dual-arm can also fold to tuck-in closely to the wall, providing a low profile that enables your display to be positioned just 2.24" (57 mm) from the wall.
The TV wall mount swivels +90° / -90° to provide maximum viewing flexibility. The mount also tilts +5° / -8°, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably. A built-in level adjustment also offers 5° clockwise and counterclockwise turning, to ensure your display is perfectly level.
The robust steel TV wall mount, with its dual-arm design and dual-stud mounting for studs placed 16" apart, provides increased durability and security. It safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes built-in cable management to keep cables neatly out of sight.
chevron icon
Product Description StarTech.com TV Wall Mount supports up to 70 inch VESA Displays, Low Profile Full Motion Universal TV Flat Screen Wall Mount Heavy Duty Adjustable Tilt/Swivel Articulating Arm Bracket - Cable Management (FPWARTB2) mounting kit - for TV - black
Product Type Mounting kit - wall-mountable
Mounting Components Wall mount, wrench, 2 vertical brackets, 2 horizontal brackets
Tilt -8° to 5°
Pan -90° to 90°
Adjustments Levelling, swivel
Recommended Use TV
Recommended Display Size 32"-70"
VESA Mounting Interface 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 300 mm, 400 x 600 mm
Max Load Weight 45 kg
Material Plastic, steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x washers, 4 x M8x50 screws, 4 x bracket screws, 4 x nuts, 2 x mounting screws, 16 x spacers, 6 x screws, 6 x concrete screws, 6 x bracket washers
Manufacturer Warranty 5-year warranty
Designed For P/N: HDMIPLATE
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£196.64
