StarTech.com Thunderbolt 3 to Dual HDMI 4K
£132.64
Delivery:
Standard: 1-3 working days
Key features
  • HIGH PERFORMANCE: Thunderbolt 3 (40Gbps) to Dual HDMI 2.0 4K 60Hz (4096x2160) Monitor Adapter | 7.1ch Audio | HDCP 2.2/1.4 | TB3 Certified | High Frame Rates | Uncompressed Dual 4K 60Hz
  • DUAL 4K 60HZ SUPPORT: Using a single Thunderbolt 3 USB Type-C port, this bus-powered dual monitor adapter supports resolutions up to 4K 60Hz on both screens and is backward compatible w/ 1440p & 1080p
  • HOST COMPATIBILITY: Supports TB3 devices incl. MacBook Pro & MacBook Air (extended dual displays on Mac w/ Intel processor; dual display not compatible w/ Apple M1 chip), Lenovo X1 Carbon, ThinkPad & Yoga, Dell XPS, Latitude & Precision, HP EliteBook
  • DISPLAY COMPATIBILITY: Video converter tested w/ 4K (UHD) & 1080p (FHD) displays incl brands LG, Samsung, Sony, Dell, ASUS, ACER, BenQ; great for content creation, imaging, & labs w/ high-res monitors
  • EASY TO USE: Driverless setup & compatible w/ macOS & Windows (some Windows PCs may not support dual video output w/ TB3); designed w/ a compact aluminum housing and 10in/25cm cable
  • Length: 28.4m
Product codes
chevron icon
chevron icon
Run the most resource-demanding applications on two 4K 60Hz displays, using your Mac or PC. This high-performance Thunderbolt 3 adapter lets you add two 4K 60Hz HDMI monitors to your Windows or Mac computer through a single Thunderbolt 3 port.
The Thunderbolt video adapter is compatible with computer systems that support Thunderbolt 3, such as models of MacBook Pro, Dell Precision and Dell XPS. Thunderbolt 3 is a protocol that uses the USB-C connector, but your computer system must support Thunderbolt 3 in order for the adapter to function as expected. If you connect the adapter to a USB-C port that does not support Thunderbolt 3, the adapter will not function.
With an unprecedented 40Gbps of throughput, Thunderbolt 3 enables you to achieve the previously impossible feat of using a single port on your laptop to output dual 4K resolution at 60Hz to two independent displays. This performance lets you run the most resource-demanding applications imaginable. You can output independent content to each display at resolutions of up to 4096 x 2160p (60Hz), which is perfect for editing 4K video or performing other Ultra HD tasks such as creating CAD drawings or reviewing medical imagery.
Functioning as an external 2-port graphics adapter with audio support, this is a compact and convenient alternative to a laptop dock when you don't need full docking capability.
With two UHD 4K displays, you can work more efficiently from your laptop, so you can accomplish more in the same amount of time. With each display delivering 4K performance, you can have four times the screen space compared to 1080p. Creative professionals can be more productive with the freedom to edit 4K video on one display while previewing raw video playback on the second 4K display.
This adapter helps to keep your system running at peak performance. Unlike USB external video solutions, Thunderbolt 3 lets you run Ultra HD 4K resolution at 60Hz on both displays without draining system resources.
Because it's backward compatible with your high-definition 1080p displays, this is a great accessory for home, office or other desktop workspace applications.
Your computer's Thunderbolt 3 ports might not function properly until you update one or more of the following on your computer: BIOS; Thunderbolt firmware; Thunderbolt 3 controller drivers; Thunderbolt 3 software.
The required updates will vary depending on your computer.
Note: In order to connect to two displays at 4K 60Hz, your computer system must have a fully enabled Thunderbolt 3 port that supports up to 40Gbps or the host must support dual displays over Thunderbolt 3.
chevron icon
Product Description StarTech.com Thunderbolt 3 to Dual HDMI 2.0 Adapter - 4K 60Hz Dual Monitor TB3 HDMI Video Adapter - Thunderbolt 3 Certified -Mac & Windows (TB32HD24K60) - adapter cable - HDMI / USB - 28.4 m
Cable Adapter cable - HDMI / USB
Max Output Resolution 4096 x 2160 - 60 Hz
Length 28.4 m
Colour Silver
Connector 24 pin USB-C - male (input)
Connector (Second End) 2 x HDMI - female (output)
Compliant Standards Thunderbolt 3
Features Active adapter, 4K60Hz (4096 x 2160) support
Designed For P/N: TB33A1C
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£132.64
